Question about Sony KDF-E60A20 60 in. LCD HDTV
No blue color, green replaced blue, white is yellow/green
There is no blue color . Green has replaced blue. Whites are yellowish green. Moving color or hue settings has not worked. I have a 60" Sony Front right of tv frame says Full HD 1080
    Novelist:
    Scholar:
  • 67 Answers
If the set is hooked up using Component cables (red, green, blue), then check to make sure the cables are hooked up correctly, and not defective (change them out). If the color problem remains, then the problem may be in the Optics block of the television (which is not unheard of in this unit).
If the menu of the TV displays blotchy discoloration, and the discoloring is the same for every input on the tv (stationary), then it is the Optics, and the optics need to be changed. It is not the easiest job in the world, and the block itself is quite expensive, although the unit my be under an extended warranty from Sony. Contact them directly to see if you can get any help (cost or service-wise). Hope this helps...
Posted on Dec 29, 2008
Problem with color on my lumix dmc-fh25 camera
Set the camera's white balance to match the lighting. Most indoor lighting has a yellowish cast to it, while by default cameras are set for sunlight.
Jan 10, 2013 | Panasonic Cameras
Phone Jack Wiring Problem
Your apartment is wired for two lines but you are using only one of the two. Your phone jack has red and green terminals for one line and yellow and black terminals for the other (old color codes). The four wires coming in to your apartment are actually two lines: orange/white and white/orange plus blue/white and white/blue (new color codes). One of those lines is active. Connect the orange/white wire to the red terminal and the white/orange wire to the green terminal. Plug in your phone and listen for a dial tone. If no tone, disconnect the first line and connect the second pair of wires. Listen again. DO NOT CONNECT ANY WIRES TOGETHER. Just follow the steps above. If you still don't get results, the phone company may not have activated your connection
Dec 30, 2012 | Lands Phones
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Wiring color code for a panasonic motor radio. Model RD535FST
Yellow - Constant 12V +
Red - Accessory 12V + (switched)
Black - Ground 12V neg.
Blue - Power antenna turn on
Grey(s) - Right front speaker (striped one is neg.)
White(s) - Left front speaker (striped one is neg.)
Purple(s) - Right rear speaker (same)
Green(s) - Left rear speaker (same)
Jan 10, 2009 | Car Audio & Video
White colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Jul 20, 2008 | Akai PT5598HD 55" Rear Projection...
Philips theater system dvd/radio/surround sound
I need your exact model number of HTS, and the manufacturer and model number of your television to be of maximum assistance.
There are a couple possibilities:
1) you could have red, yellow, and whites plugged into the red, green and blue slots
2) If you have more than one output (S-video and red/yellow/white, for instance), the signal could be splitting - try unhooking one of the outputs (preferably the S-Video)
For a more detailed solution, send me your model/manufacturer of TV, and the model of Philips HTS.
Feb 21, 2008 | JVC TH-M505 System
Sony KDF-E60A20 60 in. LCD HDTV Logo
270 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
