Question about Citizen Watches
Replacement links for OLD Noblia wristwatch.
Need watchband links for a 10+ year old Noblia watch. the watch is blackish gold and has specialized links for it's band.
  • 51 Answers
SOURCE: shorten watchband
You can find here step-by-step instructions with pictures:
How to shorten a metal watchband
It is for a casio watch, but the watchband has the same principle with "arrows" on the links.
Posted on Sep 13, 2008
escapement
  • 2334 Answers
SOURCE: remove watch band link
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 27, 2009
escapement
  • 2334 Answers
SOURCE: how to resize (remove links) from metal band on casio wtg900da8v
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Mar 21, 2009
escapement
  • 2334 Answers
SOURCE: Need to remove links in metal watch band Fossil 10
Job done!
Posted on Jul 15, 2009
escapement
  • 2334 Answers
SOURCE: I'm trying to take out links on a gold Merona
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jan 08, 2010
My adidas watchband is broken where do I can get the new one
I've never seen an adidas watch, but I'm assuming it has springbars like just about every other wristwatch does. Find a millimeter ruler, and measure the gap where the springbars hold the band to the watch--it should be somewhere between 14-22mm, depending on the watch. That will tell you what SIZE to buy, because bands are sold by width--12, 14, 16, 18, etc. Any store that sells watchbands, can find you one that will fit your watch; and some of them will even replace it for you--free of charge!
Nov 21, 2014 | Adidas Watches
Nivada wristwatch
I'd look on eBay at the completed auctions as a guide.
Jul 29, 2013 | Panerai Nivada Grenchen Mens Swiss Gold...
I need an Ann Klein watchband replacement - model 10/9168 (has gold hardware in the band). Where can I go for this replacement?
You can just call 818-2496007 (in LA) and order any anne klein parts you need. For 10/9168 watchband, its price is about 22$.
Oct 19, 2012 | Anne Klein 10 6419SVTT 106419SVTT Watch
I have 10 year old Seiko wristwatch and the hour hand does not move. Can I fix ?
no if the hour hand is stuck then it will be the movement that needs cleaning and repair. It is probably the wheel that has broken. You will need a watch maker to look at it , they can replace the movement for around 45 dollars I think for this movement . If it can be fixed it would be cheaper.
Oct 20, 2010 | Bulova Watch
Older, swiss made, ladies Eterna wristwatch
mcdevito75 here, Eterna, a nice watch with a fair collector value, It would pay to have it looked at. I am Mike D and I do work on watches, specially vintage, Locate me in the service repair secton uner watches right here at fixya, botttom of Profile page click on service repair directory, then watches, then locate me at RITE TIME BASICs, I will be glad to look at your watch, Exams are FREE.
Jul 16, 2010 | Watches
Watch runs, battery good, but continues to lose time.
If the watch is more than 4 years old, then the gears can slow down due to the lubricant drying out and leaving a gummy resdue. I use a special spray to loosen them up again and I use a special instument that causes the gears to move fast. If this all fails then it is cheaper to just replace the movement with a new one. All of this assumes that you do not have water or junk getting into the movement. Ron at TimelyWatchRepair.com
Nov 10, 2009 | Timex 27191 Wristwatch
I have an new band for the G-shock 500A but can't figure how to get the screws out of the old band to replace it. The screws turn both ways and don't seem to move. Is there some trick or special tool I...
Yes, You need two screwdrivers. One for each side. One screw on one side is long and goes all the way through the watchband and threads into the screw oon the other side which is smaller. Once you have backed the longer screw all the way out, you should be able to give the watch band a few light taps and the long screw should fall out. The screw on the aother side may require a bit more tapping or coaxing with the screwdriver to remove it. Once both screws are out, you can remove the watchband.
Sep 22, 2009 | Casio G-Shock GW500A-1V Wrist Watch
My date just will not set, it clicks two times but doesn't move
it's time for a overhaul and cleaning...the stem may be worn out. Rolexs need this service about every 10 years.
Jan 18, 2009 | Rolex Day-Date President 118238 Wristwatch
How to clean a twist-o-flex watchband
If you can take the band off the watch do it, if you can't that's ok you just have to be a little more careful. I take a 1/2 cup of HOT water, 1/4 cup of Mr. Clean, and 1/4 cup of ammonia. Hook you watch on a cup so it isn't able to slip into the cup, and let it sit for about 10 min. Take a tooth brush and spread open the links and brush away! Make sure after you brush it that you rinse off REALLY good because if you don't you will find that dust and whatever will stick to the band becuse it will be sticky because of the cleaner. If you find you have anymore problem please feel free to ask. I have been cleaning jewelry , watchbands, and watch cases likr this for twenty years , it works well.
Sep 25, 2008 | Timex 27191 Wristwatch
Watches Logo
66 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
