Question about NorStar Startalk Flash 2 Phone
I want to wipe out all programming on a nortelflashtalk voicemail
I have forgotten how to wipe out all programming on a Nortel Flashtalk Voicemail
  • vcotto493olc May 14, 2009
    After complete wipe of of all SW, now I can't log back into voicemail admin even after resetting pw for admin manager
Feature 983 log 1020000 press 1 password is 734678255
Posted on Feb 17, 2009
Why would a NorStar StarTalk suddenly stop accepting voicemail calls?
"Q: My Norstar Startalk, Flashtalk, or voice mail says my mailbox is not accepting any more messages. I deleted all my messages, but callers still cannot leave a message. Why?
A: Check with your voice mail administrator. Chances are another Mailbox on the system used up all the message storage space. Usually it's the general delivery mailbox that hasn't been checked for messages on a regular basis."
Frequently Asked Questions
The following discussion suggests that voicemail can be inactivated, and cab be re-activated by logging in and pressing '4'
Startalk Flash Won answer Nortel Phone System Tech Support
This says that the mailbox must be initialized.
http://www.uniquecomm.com/docs/Startalk_Flash_Quick_Reference_Guide.pdf
Oct 06, 2014 | NorStar Lands Phones
I have 7 Nortel t7316E handsets with only one ringing on all calls received I need to program another phone to ring also so I can have another person answer phones from another extension.
You will need to change the programming for the ext that you want to have the lines appearing on.
Enter programming - Feature **266344
PW - 266344
Press the show key - (top right arroe that is lit on the display)
Enter the ext # you want to change
this will bring you to line appearance press top r arrow
line assignment press top right arrow
show line - enter 001,002 or whatever line(s) you want to ring.
press the change softkey for each line to appear and ring instead of unassigned. Press the next (bottom r arrow) to go through each line after entering 001....
then release.
*** Make sure the sets you change are not forwarded to voicemail after a certain amount of rings otherwise all calls ringing on the newly programmed set will go to that persons voicemail.
Mar 10, 2014 | Nortel Norstar 16-Line PBX Speakerphone
Ringing only no voicemail Nortel
Forward No Answer is not working or voice mail is down.
Call your office administrator or local tech to check programming on the phone system.
Oct 31, 2012 | Nortel IP Phone 2004 NTDU92BD70E6
F 981
If none of your voicemail feature codes(f980-f989) are active, then that means that the system doesn't recognize any nortel voicemail on the system.Which means that a) your system has a non-nortel voicemail system attached to it, b) theres no voicemail attached to the system at all or c) the voicemail is no longer functioning.
Jun 23, 2010 | NorStar Meridian M7310 Phone
Setting up the Voicemail on a Nortel T7208
your mailbox number is the last 4 digits of your phone number
Apr 26, 2010 | Nortel Business Series Terminal T7208 -...
Voicemail setup
If you are asking how to setup the voicemail system, the best thing to do is to hire a technician familiar with all the installation & programming procedures. Hope this helps.
Oct 16, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Checking voicemail remotely on nortel T7208 phone
I dial my number and press ** when the VM picks up, then it should run you through the regular login process.
Sep 30, 2009 | Nortel Business Series Terminal T7208 -...
Cannot get nortel callpilot 100 to communicate with nortel CICS
This is the forums for Avaya, I would repost in the Nortel side. BUT, i do know the CICS needs to be of the correct revision to work with CP.
Apr 22, 2008 | Avaya Digital Systems&Adapters ( DEFINITY,...
Changing name in nortel T7316E handset
We would like to change the name displays on our phones
Mar 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Norstar Mailbox Problem
The mailboxes don't need to have saved messages, to be full. More then likely what is happening is that when people call in, they are getting a generic/Auto Attendant vm box, and that one is full. Try checking vm box #100, or #10. That is the Nortel standard general delivery vm box. Please let me know is this helps, or if you more help.
May 25, 2007 | NorStar M7310 Corded Phone
NorStar Startalk Flash 2 Phone Logo
317 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
