Question about AAD C10 Subwoofer
I have a aad subwoofer where can i buy the power amp that go in side it
Why does it hum?
PDF]Eris™ E5 and E8 Owner's Manual - PreSonus
www.presonus.com/downloads/.../ErisE5andE8_OwnersManual_EN.pdf
to boost much, since this can add noise to the signal. The Low Cutoff ... you are using a subwoofer in conjunction with the Eris E5/E8 monitors, and set it to the ...
Aug 02, 2015 | AAD E8 Subwoofer
Free fixing the speaker and sound in skype and video messanger?
Make sure that your laptop has a microphone and that it is enabled.
Nov 09, 2011 | AAD E-30 Main / Stereo Speaker
High range too much, bass not enough
Try placing the speakers closer to the wall or near a corner, that will help emphasize the bass response.
Feb 20, 2010 | AAD 2002 Main / Stereo Speaker
I have a Kenwood KFC-W3514DVC and its hooked up to a Valor Multimedia VPA402 500 watt 2 channel amplifier. If i want to optomize my system the cheapest way should i buy another subwoofer or should i buy a...
find the rms rating of the sub and compare it to the amp.if the rms of the amp is higher than the sub you have enough power to push the sub.if its lower look at the rms of the amp if it can be bridged.you would like to see the rms matched to the sub or subs if you have enough power.
Sep 06, 2009 | Kenwood KFC-W3514DVC Car Subwoofer
Popping during action scenes at moderate volume
the woofer is being overdriven and the voice coil is hitting the magnet structure.eventually it will damage the coil end and it will scrape in the gap.
May 14, 2009 | AAD C10 Subwoofer
Car sound
you can buy a part there the power wire goes in one side and theres two outlets on the other side for 2 amps u just need to run a new ground remote and speaker wire
Oct 17, 2008 | Sony Car Audio & Video
Stereo speaker problem
The speaker is bad. The receiver detects a shorted condition and shuts off to prevent the amp section from damage. Replace the speaker or the wires. Something is shorted.
Dan
Apr 02, 2008 | AAD E-30 Main / Stereo Speaker
Subwoofer thumping when turn on
Your subwoofer is not getting enough power, or it is grounding out due to a bad connection. What is powering the subwoofer? You might want to consider buying an AC to DC power inverter and a car amplifier to power your subwoofer. You connect the AC/DC inverter to your amp the same way you would in your car (+) to (+) and (-) to (-). The only other thing you will have to do is run the remote wire to the (+) on the amp. You can buy the AC/DC inverter at radioshack for $49.99, and all you really would need is a 200watt max amplifier and that would cost you about $10-$20.00 for a cheap one.
Feb 24, 2008 | Audio Players & Recorders
Sony AMP/Subwoofer Problem
It is probably the tweeter, inside the Sub. it's the small ceramic disk between the cone magnet, and the speaker. id this thing is cracked or broken, this will cause the problem. if this is not it, then it is a problem with something in the wiring, and the only way to rectify it is to buy a new sub. Sorry due :(
Jan 26, 2008 | Audio Players & Recorders
AAD C10 Subwoofer Logo
52 people viewed this question
Top AAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an AAD Audio Player and Recorder Expert? Answer questions, earn points and help others
