Question about Sony MBX-49 ASSY Motherboard
Sony mbx-49 Where can I find the internal fuse on the sony mbx-49 motherboard ? F2801 I believe.
  • alan susans Jul 14, 2007
    vaio pcg-fx103
Sorry for the delay responding. Info comes from http://tech.groups.yahoo.com/group/Laptop_Repair/message/646 Joe K Sony Vaio Hi Joe I have a unit now with the MBX 49 board that is totally dead does not charge battery or work from a known charged battery. The small fuse at the rear F2801 is OK, 19V on input to Q2803 nothing out from one that I worked on earlier I noted that this should have 19 on the output. This is a fet and is not being swithed on as the gate is also at 19V not pulled low as for P channel fet. Rich --- In Laptop_Repair@yahoogroups.com, "Joe" wrote: > Hi Richard, > > Does this laptop use the MBX-49 motherboard? > > check the voltage coming from the DC power jack at the back of the > unit. > > If it is the MBX-49 board, on the back of the board toward the top, > (directly behind the CPU socket) there are about 4 or 5 chips there, > those control the voltage / Speedstep / and regulation to the > processor. > > Let us know if that is the MBX-49 board. > > Joe K
Posted on Aug 20, 2007
  • 624 Answers
What model PC did this come out of?
Posted on Jul 14, 2007
  • tomj23 Jul 14, 2007
    Gsxr Nutter,
    I?ve worked on a few Viao?s in the past and haven?t run into a motherboard fuse nor have I seen any references elsewhere. That doesn?t mean there isn?t one, just means I can?t find any reference to one.
    Can you actually see a fuse on your board or are you having problems powering up your laptop? If it?s the latter laptop power issues are more typically related to the AC adaptor, the power socket/plug. Let us know..
Keyboard is not working
you might have uninstall the keyboard restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question mark ? right click update driver
if your computer came with a motherboard disc the drivers could be on it
make sure the lead has a secure seating if applicable or the usb device
hope this helps
Apr 28, 2011 | Sony MBX-49 ASSY Motherboard
Hi, i have a sony vaio laptop with no display, have tried a external monitor still no display, have lights, fans,CDRW runs any idea's ?
Please check your video card. I gues you have a defective one. If the video card is a problem, change it with same type and model.
Best regards,
geloaa
Oct 08, 2009 | Sony MBX-49 ASSY Motherboard
Memory Problems
you may have a compatible issue with the ram, your board bois may not support that manufavtures brand or coding of the chip set you are running. have some else try some other ram from another manufacture.
rod
Feb 11, 2009 | Sony MBX-49 ASSY Motherboard
Sony pcg-fx140 bootup problem
1. check bios for first boot option to hard drive.
2. If xp, run repair from cd (enable cd boot in bios).
Jul 03, 2008 | Sony MBX-49 ASSY Motherboard
Sony pcg 9h4l motherboard issue
Try to power off unit and remove the battery. Then press and hold power button for 30seconds.Put the battery back and turn it on. If it turns on turn it back off again and remove the battery. Connect your VAIO using the AC adapter only. If this will not resolve your issue you can check this with SONY or any certified service center.
May 23, 2008 | Sony MBX-49 ASSY Motherboard
CORRECT MOTHERBOARD NUMBER
hi there,
the correct replacement part number would be :- 1-680-358-11
and u can get this board at the links provided:-
http://www.notebookparts.com/products/description.php?II=12913
Apr 10, 2008 | Sony MBX-49 ASSY Motherboard
Sony Vaio PCG-FX150
The noise you can here are probably the platlettes or parking head that are present inside the harddrive. Dropping the notebook would more than likely of damaged the harddrive more than any other peice of hardware.
Aug 21, 2007 | Sony MBX-49 ASSY Motherboard
Computers & Internet Logo
597 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
