Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Unknown Wireless Router
The router I have for my wireless connection was issued by the cable company when I received my service. Where, on the router or hardware list, can I find the specs on the router to secure my wireless connection?
    Problem Solver:
  • 10 Answers
Sure U could give it a try!!
With the computer wired with the router - checked the IP address and the default gateway
Start - run - cmd - ipconfig
once you get the default gateway(say for eg., 192.168.2.1)
type the DG in the web browser andcheck for the options!!
Posted on Jan 17, 2010
I have a smartbook and i need to know who give out an ip address, is it linksys or the cable company?
The wireless router issues an IP address to your all your computers.
The ISP issues an IP address to your cable modem which is connected to your wireless router and the wireless router re-issues a local IP addresses to all the computers on your local network so all your computers on your network can access the Internet and to each other cpmputer.
May 25, 2012 | Linksys WRT54G/WUSB54G Router...
How to set up a internent connection for 2 companies both with independent lines using a single broadband connections and DrayTek V2930VN Wirelss Router/Firewall with VoIP.
The easiest solution is to use a simple router (wired-only) to connect to your Internet Service Provider.
Run a cable from one of the LAN ports on the router to a wired/wireless router, to provide access for the first company's computers.
Run another cable from another of the LAN ports on the router to a wired/wireless router, to provide access for the second company's computers.
May 05, 2011 | Draytek Vigor 2930Vn Wireless N Router...
How do i hook up a wireless router to a cable router
If you already have a cable router, then you don't want to use a wireless router. You will want to use a wireless access point instead.
The reason for this is that anything plugged-in to your cable router will not be able to access anything connected to the wireless router due to the NAT firewall in the wireless router.
If the wireless router has the option to make it a "Gateway", then that will fix this issue; otherwise, take the router back and buy a wireless access point instead.
As for how you hook up the wireless router to the cable router, you have to unplug the power cord of the cable router for about 15 minutes before hooking the Ethernet jack from it to the wireless router.
Once the 15 minutes have passed, you then can plug the Ethernet cable from the wireless router "WAN" port into an Ethernet port on the cable router and then plug-in the power cord of the cable router.
Once the cable router is finished syncing-up, the cable router should provide an IP address to the wireless router.
If you really have a cable modem instead of a cable router, then you won't have to put the wireless router into gateway mode.
Dec 30, 2010 | Linksys Wireless-G WRT54G Router
I have the RCA DCM425C cable modem and also Vonage phone service. So my modem ethernet connects to my Vonage internet. I would like to go wireless in my house. How would I do this?
You would connect from the output of the Vonage modem to the wireless router and then from the wireless router you can connect Ethernet to your desktop if you have one and then anything else can run off of the wireless.
or
get a wireless router / cable modem combo provided by companies such as netgear then you would connect the Vonage to the router through one of the available Ethernet ports and any other Ethernet connections to the router as well and anything else wireless would work wireless.
Nov 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Sep 06, 2009 | NetGear RangeMax WPN824 Router
Need nat type 2-PS3 Cable ISP digital phone modem wireless route
you can put your ps3 in a dmz zone. if still does not work its not your router. u can keep your ps3 in dmz and get your router to open ports. u can call your router company. If still does not work its not your router more than likely. It might be your modem. i have at&t and that was my issue. i went to dmz on modem and allowed it to pass through dmz zone and ip addresses to pass through. but make sure on your comp u have spyware or something. Your ps3 can not get virus.
Sep 06, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Keep losing the Signal
This is a fairly simple thing to trouble shoot. If you are losing your wireless signal where your OS tells you that you have been disconnected from the wireless network then there is an issue with your wireless router. If your cable modem drops the data link to your ISP your wireless network will still work 100% fine, however websites will not load, but the router admin page should.
The end all be all way to prove it is not your wireless router is to simply use a network cable for a few days and see if you get the same issues. If it does turn out to be your wireless router there could be an issue with interference and I would recommend trying a different wireless channel.
Aug 12, 2009 | Microsoft Broadband Networking MN-500...
Can I use my router just as a Wireless router with a DSL .
i doubt it will work. most times the cable companies give you a modem/router all in one box. the problem is there in no inbound connection to recieve an internet signal other than the cable cord connection. with the dsl modem you will need a seperate router. they cost around $40-50 on avg
Feb 05, 2009 | Arris SURFboard SBG900 Wireless Router...
Hooking linksys to gigafast
There are some question's that should probably be asked before we begin. Generally a wireless adapter or network card is present in a computer to allow it to access a wireless router which is connected to an internet service provider (generally a dsl connection through a phone line or a cable modem from your cable provider. Your request seems to be to get a computer to talk to a wireless router to talk to a wireless router to talk to your internet service provider (dsl or cable). I will assume after reading this that you probably have or will get a wireless adapter for the computer to talk to one or both of the wireless routers you appear to have. Wiring two wireless routers in the same house may be useful if the home is large or the wireless routers operate on different bands (a, b, g or frequencies) and you have different computers that require the different bands. however both wireless routers are in my experience connected to each other using a wire. Once we clarify the above we can probably address the connectivity issues for the devices you require.
Dec 02, 2007 | Linksys Wireless-G Broadband Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
