Question about Kenmore 15864/15862 Top Load Washer
? water won't start on my kenmore 70
Could the fuse be the problem?
How do I get to the fuse on the Kenmore 70 top loading washing machine?
  • iliiinieis Jan 03, 2009
    I have the same problem except on a 90 series. i think its the water inlet solenoids. Its only cold that wont run. I bought the part already, looking for a manual to tell me how to replace it.
    Novelist:
  • 101 Answers
It's not going to be a fuse. The person that has the same problem is on the right track. There are two solenoids on the water inlets, one for hot and one for cold. Check and see if it works on one but not the other. Then take off the hose to the one or one's that aren't working and try cleaning the screens first. There are small little screens inside of the inlets and if you have hard water or anything it will build up on those screen making it so the solenoids don't turn on the water. A simple cleaning of the screens may fix it. If not you may need a new inlet solenoid. Those can be picked up at your local appliance repair shop. Just give them the make and model of your washer. I hope this helps and if you have any other questions let me know. Good luck.
Posted on Jan 22, 2009
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
Is there a fuse for the 70 series washers? Mine wont spin the water out...
No user-servicable fuse that I'm aware of -- I sell Kenmore appliances. If it won't spin out water, it's probably a bad pump. Does the motor run? Can you manually advance the timer? If so, you may have a bad timer.
Oct 17, 2010 | Kenmore 24032\24036 Top Load Washer
How do I remove the pump from a kenmore 70 washer?
The Kenmore 70 series is a top loading washing machine. Different from the picture you have this listed under. If this is a Kenmore top loader, the following link explains how to replace the water pump:
http://www.fixya.com/support/r397092-replacing_water_pump
If this is a front loading Kenmore, the next link applies:
http://www.fixya.com/support/r401841-replacing_kenmore_elite_water_pump
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
Jul 15, 2009 | Kenmore Elite 45986 Front Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
Kenmore 70 series
INLET WATER VALVE ON BACK BAD,THANKS-MIKE
Jul 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series won't turn on
Sounds like the fuse may be gone. If your front panel comes off it may be in there.
Jun 01, 2008 | Kenmore 22422 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
32 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
