My sony monitor seems to have some problems coming out of standby. When in standby the amber led is lit. It changes to green attempting to come out of standby but then the amber led comes on again but this time blinking. The only way I can get the thing going again is to shut down the pc and pull the power plug and video cable on the monitor. Then reconnect the power and video cable and restart the pc. This fault does not happen all the time but is annoying when it does.
-   Same as above. Mines just started doing this. The flashing orange led is a fault code for the monitor.-   Guest
Mar 13, 2008
-   Shortly after I turn on my 19 inch Sony Multi-scan monitor and it makes a audible click and the light goes from green to flashing amber and the screen goes blank/black. I used to be able to get it back by powering it off/on but now it switches off within a couple secs every time.-   jimzim37
bear.....my HMDA400 CRT Sony ..is doing the same thing....you need to discharge the CRT of static, then open the case and vacume the boards, heat sinks and every thing soldered down, strap grounds and the glass tube CRT.
Then run the self diognostic from the manual ..its simple and will tell you if the problem is major...usually it is a pwr issue...ie the pwr strip outlet may be shorting or pulsing erratical out put....bad strip......if the self diognostic shows the monitor is bad....best thing to do is replace the main monitor PC board to avoid testing other componants with speciality equpment you don't have! Last resort replace the CRT...the most expensive piece of the puzzle...ie the picture tube it self...
try a good known monitor on your system to be sure you don't have a software, or CPU problem or pwr glitch.....know this ,a black screen with no raster(lines, visuals) could be a sign of a faulty FBT(fly back transformer)...it happens with CRT units...sucks doesn't it...and you would be advised to" wear rubber gloves" to replace the FBT yourself....because of the dangerous voltage stored in the damn things.....its the current not the voltage that is deadly.....two hands on any circuit is not good....one hand at a time when taking parts out and putting them in.....get rid of rings watches and other conductive bling on your wrists and hands!....you will thank you me for that! good luck!
Was this helpful?
Yes
No
Popular Solutions for Sony CPD G420 19" CRT Monitor
I have a Sony G420 CRT monitor which is starting to get too bright. There is a fix for this but in...
(More)
I have a Sony G420 CRT monitor which is starting to get too bright. There is a fix for this but in order to carry this out I first need to 'unlock' the control panel on the front of the monitor. For some reason the 'picture effect' button is unresponsive, while depressing the 'menu' button only gives me the manufacturer's date. My initial thought was to look for a firmware upgrade, but as I am on a Mac I am unable to find a suitable installer. Has anybody else struck this issue?
i have a 19" Element tv and when i turn it on it turns on and displays element on the screen...
(More)
i have a 19" Element tv and when i turn it on it turns on and displays element on the screen before it turns off again, i opened it and saw that the top and bottom light tubes were burned, does anybody know where i can find those tubes. I've been looking everywhere on the net but i cant fint them... Thanks in advance....
The picture on the screen is too wide. it has choped the RH side off.How do I reduce the width and...
(More)
The picture on the screen is too wide. it has choped the RH side off.How do I reduce the width and then centre the picture?
no it is not my failing eyesight - haha!
i have just noticed in the last while that the text on...
(More)
i have just noticed in the last while that the text on the screen is becoming very hard to read - all users have noticed this. looking very slightly out of focus.
i cannot find a sharpness function for this monitor?
can anyone help?
the monitor is on a G4 mac, and up till now has been the best monitor we have ever used. thoroughly recommend it for those needing accurate print colour.
thanks heaps.
mike
