Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
I am looking for a part for my furnace, but i am not entirely sure the name of the part... this makes it very hard to find this part and we have no heat.
  • 1 more comment
  • aquila-mm07 Jan 02, 2009
    Germz1979, your heater seems to have a newer part number than mine but they all basically have limited and similar parts. Additionally, they are well marked and readily visible assuming you have enough light. Most of the time it's the thermostat that dies as many of the newer ones are made in China and have lower cost parts. After that, it's either the pilot igniter system and/or the main gas valve. If the ignition system is a Honeywell go to Carrier's, or Honeywell's website and search for Intermittent Pilot Gas Burner Ignition System.
  • Farley Redfield
    Farley Redfield May 11, 2010
    Judging from the date he must ahve fixed this by now....
  • Danny Clark
    Danny Clark May 11, 2010
    OK, so describe the part and what it does and I'll help you figure out what you need.
    Also tell me what the unit is doing/not doing.
    Problem Solver:
  • 13 Answers
Please pull burner compartment panel off and look for manufacturer
Ydecal. This will provide manufacturer name, model and serial number.
You should now be able to locate parts through local H.V.A.C.
wholesaler but they may not sell direct to you unless licensed.
Posted on Aug 04, 2009
Leviton RC 1000. I replaced the old HAI thermostat with a new RC 1000. Four wires to drive furnace and AC, there was no common wire attached. I also connected the thermostat to my HAI controller per the...
it might not be compatible with the furnace and ac system you have. I would make sure that it is, also read the manual book some wires you can tie in together to plug into the same lead. JUST FYI AC and Furnaces are really fancy now and have a computer chips in them... so i would investigate.
Nov 24, 2014 | HAI Omnistat2 RC-1000 Thermostat
Inducer Motor Noise
Bad induction assembly is common with these units. If it's the style that has the motor install in what looks like a square black plastic box with tube connections off to the left and right. Replace the whole assembly, not just the motor. If you are mechanically inclined replacement isn't to hard.(make sure electricity to furnace is off). Cost to purchase induction assembly(look online) is around $300. If you have a company do it expect a bill between 650 and 800.
Mar 14, 2014 | Bryant 352AAV036060 352AAV 60,000 BTU, 92%...
New Payne Furnace PG95SAS How to hook up wires for powering
MOST UNITS HAVE KNOCK OUT WHERE THE POWER GETS HOOKED UP, HANDY BOX WITH A SWITCH NEED TO BE ATTACHED, MAKE SURE YOU ARE USING A GOOD GROUND, AND HARD WIRED NOT AN EXTENSION RUNNING TO AN OUTLET.
Dec 08, 2013 | GE 1/3 Hp Furnace Blower Motor...
How do i read american standard freedom 90 error codes
can you look thru the small circle window of the cover of the furnace panel? to see the red light on the furnace control board. If you can see it. Count the blinks of the light. Also keep track if they are long flashes or short quick flashes. they might be 2 long flashes and 1 short or 5 short and 2 quick. After you determine the flashes or the sequence of the flashes. take the cover off the unit and look on the inside panel of the blower door. it should give you the code sequence of the problem you are having on the legend of the wiring diagram. or if there is no legend or wiring diagram on the inside panel of the blower door. it will be in the paper work or unit information package paperwork that came with the unit. If you don't have that. You would need to get the model number of the furnace from inside the furnace. the model number is usually inside the blower door or it could be close to the burners of the furnace itself. if you don't have the wiring diagram or the paper work. then you will need the model number for sure. I think you can go to American Standard.com and look thru their online library of unit specs to get that info. to look thru their library you have to have the exact model number or I believe at least the first few numbers of it. Not sure how many of the first few you need to have. if you cant find the info and have the model number. Give it to me & I will find it for you. Or see if I can find it? americanstandardfurnace.com I think is were it is. Or at the American Standard home AC & Furnaces home page you can search for it. It shouldn't be too hard to find. Or another way would be to call a American Standard parts or unit vendor and tell them your name is Dave or some other common name. And that you work for sears or some other large company like that or a large company in your area. And that you need tech support to get you the code info for that specific unit. If you call when they are busy they usually wont verify the company info or that you do work their. just hearing the company name, they will think you work for that place and get you the info. At most wholesalers they are just trying to make sure they aren't talking to a home owner or a regular person. when they hear a company name they will give you the info you need or tell you were to get it. Also its a good idea to be prepared when you give a company name that you work for or that you don't really work for. the guy on the phone will ask for the name of the company you work for. My name is Dave & I work for sears service. the one on Broadway Road (give them the address and or phone number) of the place. Some places use the phone number of the service place to look up their account and they will have a list of names and want you the verify the address or the phone number. Works good for getting info about a unit that you cant find any info anywhere else. But trying to get parts that way doesn't usually work unless you know how to do it. I would say but not sure these guys on fixya would be okay with that. Hope they don't have a problem with me saying how to get info from a vendor about a trouble code or where info for a code can be found. if they don't like it I am sure I will find out soon enough. and hopefully they will give me another try at this before taking any actions on me or on me being on here.
hope I was of some help to you. if you haven't already figured it out or if no one else has tried to answer your question.
Apr 06, 2013 | American Standard Heating & Cooling
THE BURNER WONT LIGHT
The failure of the appliance to start at all can be one of the most worrying washer dryer problems. However, this may often just be due to the door not being closed properly. Try opening and closing the door to see if this makes a difference. Otherwise, there is likely to be a fault with the sensor or pressure pad that detects when the door is closed. Try wiping the door and the corresponding latch on the machine with a clean cloth before testing it again. It is also a good idea to check the seal around the door to ensure that it has not sustained any damage.
  1. Before you attempt to fix a furnace that won't start, make sure you know what kind of furnace you have. This ehow is strictly for a forced air, gas furnace. Check to make sure the furnace filter is clean. If not, replace the dirty filter with a clean filter. Also, check to make sure power to the furnace is on. Finally, make sure the gas supply to the furnace is open.
  2. If your furnace clicks on or initiates the start cycle, but does not fire up, you likely have a faulty or dirty ignitor/sensor. This is one of the most common furnace problems. Under normal conditions, the furnace is notified by the thermostat to click on, the ignitor gets red hot and then initiates the entire process of igniting the gas and blowing the hot air. Check the error codes in your furnace user manual to make sure you do not have a more serious problem.
  3. To fix the furnace that won't start, turn off the power to the furnace-and turn off the gas. Remove the front panel and look for the ignitor/sensor. Refer to your user manual to locate the ignitor. It is usually located near where the flames shoot out of the burners.
Dec 24, 2010 | Dryers
Where is flame sensor on my old oil furnace?
Thanks for your question,
The flame sensor eye is located just under the transformer, it is looking straight down the burner assembly to where the burner chamber is at, you will have to remove the entire assembly to get to it, first make sure the power is off, remove the transformer, then remove the entire burner assembly from the furnace cabinet, once removed you can see the flame sensor window, use a clean oil free cloth to clean it, it would probably be a good idea while you have it out to replace the burner nozzle, as over time they will clog, I hope this helps you fix your oil burner, let us know and rate this please, thanks again,
mr.grzz
Jan 27, 2009 | Heating & Cooling
Tstat wiring
Thanks for your Question,
one of two possiblities, first and most likely is that you have blown the Transformer in the Furnace, second would be that you have blown the small car fuse that is on the circuit board in the furnace, if you look really hard you will find it, it looks like an automotive fuse, should be about three amps, if it is the fuse, then its a simple fix, make sure the power is off, replace the fuse, if its the transformer, a little more involved work is needed, but still should be pretty straight forword, and again, please make sure the power is off when replacing, hope that helped ! please be sure to come back and let us know how I did for ya, thanks again,
mr.grzz
Jan 22, 2009 | Goodman CLQ36AR49 Air Conditioner
No Power
Try holding down F8 when restarting pc. Choose safe mode and run your AntiVirus again. Make sure to empty any quarentine items.
Sometimes this finds a few more. Make sure to turn off system restore before scan and turn back on after.
If this doesn't work you may need to do a format and reinstall your operating system. There are also Hard drive viruses too. If you remember the name(s) look them up on internet for severity level.
Jul 22, 2008 | E-Machines eMachines Desktop PC
Verbatim Portable hard drive ? download entire desktop with applications ?
Don't know why you might want to do this, but assuming the portable drive is equal to or bigger than your system drive (C:), I would recommend you check out Ghost software (not sure of name) but this will put you on it. With Ghost, you make a mirror image of an entire hard drive. I used it to make multiple copies of entire PC's for classroom use.. i.e. Load one PC with all the OS and program software, and then connect other drives to the "Master" one at a time, until I had a classroom full of identical systems. Had to pull the drives, but since yours is already external, connectivity would be the only issue. USB should work, I would think.
May 25, 2008 | Verbatim Computers & Internet
GMC FURNACE MODEL GMPN060-3
Sounds like s safety or overheat switch is tripping. Clean or replace air filter, inspect the venting for restrictions and make sure all registers are open all the way and not blocked by furnatue. Also check the condensate to make sure it is draining. If it continues to not heat, call a technician.
Jan 22, 2008 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
57 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
