Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Machine stuck on Cycle and wont cancel
Started the fast spin cycle and the machine just keeps filling up with water. It won't drain and when you try and cancel the cycle the machine switches itself off. When you turn it back on its still stuck in the same place and the machine is still filling up with water... the door lock light is on but no others , not even the fast spin cycle where it should be. HELP !!!!! tried taken the front filter off but have turned it anti clockwise as far as I can but it won't come out. Checked drain pipe, not blocked.
  • s_hellerman Dec 31, 2008
    Hi got the filter off, it was jammed by coins !!!!! empited it but still no luck. Machine is still stuck on a cycle where it's just filling up with water and when I try to cancel it its as tho the machine trips out and shuts itself down. When I unplug it and plug it back in its still stuck on the same cycle..... filling up with water... and it doesn't even attempt to drain it. Even if I try to press any of the buttons the machine trips out. Its Model number WT540 1400 spin, Hotpoint washing machine.
    No this is fine I can see the water filling up in the machine. I've had to switch it off at mains through concern that it will fill up to the point of bursting !!!!
  • Hotpoint Master
  • 3,463 Answers
Chances are it is the filter that is blocked, you must remove it completely to check,
Pull ******* the filter to remove it,at worst you may have to break the filter to get it out, it would just mean replacing it with a new one.
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
  • Barry Coates
    Barry Coates Dec 31, 2008
    Make sure the drain out let hose is not too low as this will cause the water to syphon out as it is filling.
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
this could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Dec 08, 2014 | Samsung Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
It keeps getting stuck on rinse cycle a
Check it out....
Good Luck!!
thanks
Jul 19, 2009 | Fisher and Paykel Washing Machines
My GE washer will not run a full cycle. It fills up non stop, while at the same time its draining. It was running the cycle and would get stuck on the rinse/spin cycle. But now the knob doesn't even move...
One very slim chance is that the waste water hose does not have an air break in it
The pipe is supposed to be placed into a drain which allows a flow of air to the pipe out of which the water is being pumped
If there is not an air break then the mchine can set up a syphon action which will not allow the unit to fill to the right levels
Quick check is to dump the oulet hose into a sink and run the machine , be sure to secure the pipe in case it slips out and also that the sink can empty fast enough for the water being pumped into it by the washer .
If you are saying that the machine wont stop filling try turning the water off at the fawcet
Jul 05, 2009 | GE Washing Machines
Kenmore elite catalyst wont drain or spin
Did you ever find out what is wrong? This is exactly what has been going on with ours.
Mar 25, 2009 | Kenmore Washing Machines
CANT DRAIN OR SPIN WATER OUT OF MY WASHER
you have a clogged water pump....its simple to unclog but thats whats wrong a clogged water pump
Jan 29, 2009 | Washing Machines
Hotpoint WT540 1400 spin Washing Machine stuck on cycle
Could be a sticking water level switch, which controls the water level, or a blockage in the hose to the switch, or a trapped or split hose to the switch. the hose in question is about 6mm in diam,and goes from the sump hose to the pressure switch,if u remove the hose from the preesure switch chamber, check for a blockage there, and blow down the hose to see if it is clear, u should hear the switch click if it is clear, if no click and hose is clear, then I wud say the switch is faulty.
Plz rate my comments.
Thanks
Dec 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
158 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
