Question about Kenmore 63692 / 63694 / 63699 900 Watts Microwave Oven
Replacing interior light bulb in m/n 63694
How do you access the interior light bulb in m/n 63694? It doesn't appear you can get to it from inside. Is there an access cover located on the top/outside cover? Thanks....
  • Kenmore Master
  • 9,149 Answers
On many recent models, it is necessary to remove the mircowave from the wall, then remove the cover to change the cavity bulb. They suggest that only an authoirzed servider replace them, in order to avoid liability. You can enter your actual, full model number (63694 is not enough) and get helpful exploded view drawings and order parts at http://www3.sears.com (the three is correct). Do not handle the bulbs with bare skin, it will shorten their lives. Use a clean dry cloth or gloves.
Posted on Apr 29, 2007
Change interior light In my ge pvm1870sm3ss microwave
have to take the outer shell off to access the light .
Mar 09, 2016 | GE Microwave Ovens
How do I change light bulb under a 2009 ge microwave/model no.lvm1750dm1ww
The range top bulbs can be replaced by removing the screw that holds the glass and frame to the underside of the unit, they swing down, the bulbs usually screw in, the power needs to be turned off by way of unplugging the unit before replacing the bulbs, the interior cavity bulb can be replaced by removing the top grille and accessing the socket assy from the front. Pleazer Appliance...
Dec 22, 2014 | GE Microwave Ovens
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
The bulb light inside the microwave went dead with the microwave working perfectly...how do I replace the bulb?
Replacing the cavity light requires taking off the outer wrapper to access the bulb. Nothing easy or magical just an exercise in patience.
Eric
Jul 05, 2010 | Maytag MMV4205 Microwave Oven
INTERIOR LIGHT
You need to replace the internal light, that usually can fix the problem.
If replacing the bulb does not work, check the wiring to the light.
You can find the spare light and diagrams for your oven by entering model number here.
Feb 27, 2009 | General Electric Advantium 120 Microwave...
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing lightbulb in Sharp R953M combi microwave oven
most microwave ovens built in the last 20 years do not have an
access panel to the light bulb. you must remove the screws on the back of the microwave that hold the outer sleeve in place.
Then pull upward and backward on the sleeve to disengage it
from the front lip of the chassis. the light bulb should be close to the front of the microwave behind the control panel. Some lights
are not unscrewable from the socket, but the socket and bulb
come as an assembly.
Mar 26, 2008 | Microwave Ovens
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Interior light gone out
There is usually a little window inside that might remove with screws, or even snap in. That should allow access to the lamp. Check the manufactures website under product support for more info.
Jun 24, 2007 | Neff H7871N2GB Convection / Microwave Oven
Kenmore 63692 / 63694 / 63699 900 Watts Microwave Oven Logo
207 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
