Question about Garmin nuvi 650 GPS Receiver
Garmin nuvi 600/650 windshield mount
Where is the best spot on the windshield to mount my
Garmin nuvi 600/650? I live in New York
SOURCE: Audiobooks on a Garmin Nuvi 650 GPS
I am trying to download books on CD to my Garmin 650. How can this be accomplished?
Posted on Feb 06, 2008
SOURCE: garmin nuvi 650 unlocking
go to location where you set the code or send it to Garmin to unlock
Posted on Jun 27, 2008
  • 218 Answers
SOURCE: Garmin Street Pilot c340 mount
Try a hard reset using the reset button under the silver trim on the front. Pull off the trim ring by hooking your fingernail under it right below the logo.
If that doesn't work, then take the unit off of the mount for a better look at the contacts. Re-seat the mount onto the unit and see if that helped. If the mount is damaged, consider getting a friction mount instead of the suction cup. For about $40 you'd get new power contacts and a new cord, and the unit would sit on your dash instead of falling off the windshield all the time.
All of this is assuming that the problem occurred suddenly after a fall, and that your battery is still good.
Posted on Oct 13, 2008
  • 1111 Answers
SOURCE: my garmin nuvi 650 will not go to next screen it
have you tried the master reset?
plug it in to the usb port on your computer for a few hours.if that fails,then try the master reset.
note: that the master reset will erase all your saved data
with the unit off,and unplugged, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
if that fails, hook up the nuvi to the web updater and get the latest update.
download the updater HERE
(actually i would do this either way)
bill
Posted on Sep 27, 2009
sharcnet
  • 2130 Answers
SOURCE: The touch screenon my Garmin Nuvi 600/650 won't
This is a common problem with units having the serial numbers beginning with "14V", "12P" and "143". It's caused by a defective SHARP touchscreen and needs to be replaced. Please see this link for more info:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Jan 21, 2010
My Garmin Nuvi 3790T will not acquire a satellite signal
Does the GPS work outside of the vehicle?
Where is the GPS mounted?
If the GPS is under the dash, mounting it up on top of the dash will help.
If the Vauxhall has a windshield with a reflective metallic coating or treatment in the glass, this may result in poor GPS satellite reception.
Apr 12, 2012 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
Live in Toronto Ontario Canada...garmin jumps always to New Brunswick and cannot find a match for Ontario..always opens in New York
Go to Where To...... Address...... on top of screen you have where its searching saying ( Select City in )
to change that look on bottom of screen there is .... Change State / Province
Oct 29, 2010 | Garmin nuvi 1300 Car GPS Receiver
My windshield mount for my Nuvi 660 came apart. The suction piece came apart from the plastic mount. Can you send me a new windshield mount? Thanks
FixYa provides answers only, it does not supply physical goods of any kind and has no connection of any kind with your product supplier/manufacturer.
So no, it's not possible for FixYa to provide spare parts, sorry.
But Garmin can. Click here for their online shop specific to your model. You might also find the same thing cheaper elsewhere on sites like Amazon, eBay and from other suppliers.
Good luck and please take a moment to rate my answer.
Jul 27, 2010 | Garmin Nuvi 660 GPS Receiver
Where do i mount my garmin nuvi 1300t in my 08 ford focus apparantly the windscreen can interfere with the signal
Windshield should not affect the signal. However if you are mounting it high up and there is a grid antenna in teh windshield that may cause a problem. try mounting it low down
Dec 10, 2009 | Garmin nuvi 1300 Car GPS Receiver
Sticking my nuvi 260W to windshield - after a few days often in sun [winter/spring Mass.] thesuction cup mount falls of to dashboard- risking damage to nuvi. advice? without having to use permanent...
Here is what I do. I clean the spot on the windshield very good with Windex or another good window cleaner. I also clean the suction cup surface while I am doing the windshield. Next I place the GPS next to the Rearview Mirror. and connect the suction cup. Then I take the power cord and use it to tie a knot around the suction cup mount and then I loop it around the Rearview mirrow twice leaving no slack between the GPS and the Mirror. Be sure to not block you view in the mirror. If the GPS come loose from the windshield it will just fall far enough for the power cable to catch it and will just be swiing there instead of falling to the dashboard or floor. This is kind of a Mickey Mouse way to do things but it works.
Apr 08, 2009 | Garmin nuvi 250W GPS Receiver
I have two NUVI 660's and one 360 (?) navigation systems. They all work great except all three have the same problem with the suction cup. Aftera few months, they will not stay attached to the...
Hello rkfowler,
While the suction cup mounts included with most GPS units are very effective, they certainly can fail. It sounds like you are doing everything you can to make it work: cleaning both the windshield and the cup itself. You also might try putting a few drops of water onto the suction cup before affixing it.
If the suction cup mounts aren't working out for you, Garmin does have a couple of other options including a vehicle mount that uses a super strong adhesive or a friction style mount. These are available from Garmin directly on their website (www.Garmin.com) or through your local consumer electronics store, such as Best Buy.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 08, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 650 GPS Receiver Logo
154 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
