Home | Nintendo | Wii Console | Wii will not power on
Nintendo Wii Console
Problem for Nintendo Wii Console
By nwhite1 on Dec 29, 2008
wii will not power on
Same Problem
Nov 20, 2009
-   Thanks alot for the unplugging information......Worked like a charm-   j_azzaro
May 26, 2009
-   My wii was not even 2 months old and the power just wasn't on one day and wouldn't come on. I read some other posts and tried vacuuming out the vents and unplugging the power cord at the same time and it worked! I recommend doing this before you send it off for repair or buy a new one! -   Guest
Apr 19, 2009
-   Mine is doing the same thing..I just bought my wii probably a month ago!!-   Guest
Mar 30, 2009
-   its not working still -   Guest
Mar 23, 2009
-   my console is plugged into the t.v. and the power cord is plugged in to the wall and my console will not turn on-   froggy696979
Best Solution
posted on Feb 15, 2009
Helpful)
kudrik007
Rank: Apprentice
Rating: 87%, 29 votes
The light on our Wii would not turn ON, and would not power up. No red, no yellow, nothing.
To fix, we unplug the Wii console. We turn the WIi console so that the back-side fan area is pointing towards the ceiling and then vacuum the fan area. Then we place it back into the Wii stand, plug it in, and the red light comes on. It powers up and works perfectly again. Obviously this won't solve everyone's issues (i.e. electronic component failures), but it has worked several times for us. Definitely worth a shot before shipping your unit off for repair.
I think the fan gets clogged and WIi protects itself from overheating, but do not really know why this works... but it does!
Was this helpful?
Yes
No
22 people thought this was helpful
Solution #2
posted on Mar 04, 2009
Not Helpful)
Go88
Rank: Apprentice
Rating: 48%, 5 votes
Worked for me! Thanks
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Nov 09, 2009
Very Helpful)
gerla20
Rank: Guide
Rating: 91%, 29 votes
work for me thanks i was scared
Was this helpful?
Yes
No
Solution #4
posted on Mar 20, 2009
Very Helpful)
Jillisawesom
Rank: Guide
Rating: 81%, 4 votes
Hello my friend, i had a Nintendo wii, until i figured its a money eating machine,
i had this, went to Nintendo , they examined it and gave me a call after 1 week, apparently, the fuse inside the wii, is burnt, i asked why, they say it was a electricity failure
they're right, my wii turned off because of the electricty cutting off for a second, however i still lost a good amount of money !
Comments:
Mar 20, 2009
- also, if the fuse is burnt, smell ur fan and you well fastly discover that if it burnt or not !
Was this helpful?
Yes
No
Solution #5
posted on Apr 17, 2009
Very Helpful)
Moose72
Rank: Apprentice
Rating: 98%, 10 votes
Unplug from the wall for a couple of minutes, then plug it back in. It has nothing to do with the fan. The Wii power supply turns itself off when there is inconsistent power to protect itself (i.e. if the power is coming on and off in a storm) Unplugging for a couple of minutes resets it.
Was this helpful?
Yes
No
9 people thought this was helpful
Solution #6
posted on Mar 26, 2009
Helpful)
Ima-Addict
Rank: Apprentice
Rating: 94%, 9 votes
If the Wii will not turn on, unplug it both from the Unit AND the Wall for a couple of minutes, thats worked for me before.
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #7
posted on Mar 28, 2009
Helpful)
chris14254
Rank: Apprentice
Rating: 93%, 7 votes
I had the same problem intill my brother blew in the fan in the back and alot of dust came out then it worked perfectly
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #8
posted on Apr 19, 2009
Helpful)
person447
Rank: Apprentice
Rating: 83%, 3 votes
unplug your wii then take it out and hold it over your head and turn on the fan and in a few minutes it will work. They are ushally just dusty
Was this helpful?
Yes
No
Solution #9
posted on Jul 23, 2009
Somewhat Helpful)
lucy222
Rank: Wiz
Rating: 79%, 12 votes
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-114
Was this helpful?
Yes
No
Solution #10
Somewhat Helpful)
tuneguy3
Rank: Apprentice
Rating: 75%, 8 votes
plug it in. Duh
Was this helpful?
Yes
No
Solution #11
posted on Oct 06, 2009
Not Rated)
damonaf
Rank: Apprentice
Rating: 0%, 0 votes
I had this problem with my Wii that it would not turn back on so I took out the battery ( which is on the bottom undo the screw and pull out the battery. Make sure the power cord is not connected. Put battery back in and hooked back up to power. You should have a green light and Wii should be ready to go.
Was this helpful?
Yes
No
Popular Solutions for Nintendo Wii Console
Questions and Unsolved Problems for Nintendo Wii Console
Do you recommend Nintendo Wii Console?
Answer
Answer
I have a new WII and can't get it to work. I'm using a Sony TV and a Sony VCR --- WII pluged into... (More)
Answer
Remotes keep flashin blue lights. Went through the four step process to re synch but they stll flash... (More)
Answer
wii control does not light up it has brand new batteries.
Answer
all wii games now only show in brown, yellow and blue No red or green colors on any game. component... (More)
Answer
I have been having problems with the wii freezing at the health start up screen, so I decided to... (More)
18 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 20, 2009
same here.....and i bought it from amazon
Comment by Noecrew, posted on Mar 05, 2009
Same problem! Will not power up. Have checked cords, vacuumed fan, checked outlet. Still no power. Have only had it 8 wks!!
Comment by Guest, posted on Mar 02, 2009
Same problem!! There seems to be a pattern forming here.
Comment by chas_heather, posted on Mar 02, 2009
I have only played my wii 3 times it is a week old and now will not power on! I unplugged all cords and retried still will not power on
I just got my wii a week ago, had to take it back because the piece that holds disc was broke. Now This one worked 3 time now will not power on. Tried unpluggin all cords and reconnecting then, still no luck. Its only been used 3 times in 1 week...whats the deal??
Comment by lindawall, posted on Mar 01, 2009
unit plugged into power but won't power up. no light on
Comment by Guest, posted on Feb 28, 2009
the light on the wii on/off button is not on just has the black lining
Comment by Guest, posted on Feb 18, 2009
same issue....no luck with vacuum trick here though
Comment by Guest, posted on Feb 16, 2009
Exactly! Same here.
Comment by Guest, posted on Feb 15, 2009
SAME!
Same problem, no power light, no start up. Was a batch of Wii's programmed to die in mid-Feb'09?
Comment by Teri8374, posted on Feb 12, 2009
My wii will not power up. I have checked cords, breakers, outlets everything but it will not come on at all
Comment by Guest, posted on Feb 12, 2009
Th ewii will not power up. Checked cords, outlets and ports nothing happens
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nintendo Wii Console:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 741
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Video Game Console Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
