Question about Protron PLTV-32 Television
(menu)blue light on the TV flashes on and prevents volume control
Please help
  • 1 more comment
  • bobjech Dec 29, 2008
    our TV has a small blue light that flashes with menu on it...when it flashes we can't operate the volume or turn the TV off
    the picture is fine..the tv only acts-up when the light flashes and we lose control of the volume and have to manualy turn the tv off
    how do we get the blue light to stop flashing?
    i have lost the service manual and was unable to find Protron in the options to purchase one. Proton was metioned that i could purchase a manual but not Protron. Are they the same company?
    Master:
  • 479 Answers
Yes they are compitable but not exactly same but you can go for it. reply for further queries. thanks.
Posted on Dec 29, 2008
  • 199 Answers
Try to flick, snap or jar with your finger/finger nail the button at the front panel of the TV especially the MENU (and all others). It or any may have been stuck on the pressed condition.
Hope this helps.
  • 177 Answers
Never heard of Protron- is it a good brand?
You may need to take it back to the shop you bought it from and have them check it out by one of their technicians, if not the maybe the aerial need to be replaced or pickups need to be installed to get better reception!
--P3NGYJ03
  • 1 more comment
  • Jackson Henney Dec 29, 2008
    I think it is an electrical fault in the TV causing this. Don't attempt anything by yourself though because it won't only void the warranty but also might injure you.
    Unplug the TV for 5- 10 minutes and then plug in, see what happens, please post what happens
    --P3NGYJ03
    Proton is a Car manufacturer.
    Protron is a TV manufacturer.
    Check out this website:
    http://forums.cnet.com/5208-7596_102-0.h...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, I am assuming that you concern is that the Protron PLTV-32 when powered on just flashes a blue LED. If it were so, this indicates that the TV has switched to auto protect mode to prevent further damaged to itself. This has been triggered when the unit senses a fault within itself while performing a built-in diagnostics on start-up. In some instances, unplugging the TV for an extended period of time would simulate a reset and revert the TV back to factory default.
Having said the above, more often, the number and sequence of flashes/blinks could represent an error code. The error code in turn would correspond to a probable area/section that is faulty. This then would be instrumental in selecting which area of the TV to start the check/diagnosis.
This of course would require opening the unit, perform voltage measurements, determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you however be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 30, 2008
    Any updates or developments?
    Genius:
  • 2,920 Answers
Usually means you are losing reception.i would have it checked if at all possible.
    Sergeant:
    Novelist:
  • 326 Answers
Explain ur problem in more detail plse
  • technodeal Dec 29, 2008
    ok its simple to solve --press the function button and menu button together on your remote pointing towards tv for 5 seconds to solve this problem.
    Novelist:
  • 163 Answers
Please discribe your problem.
  • ronny2051 Dec 29, 2008
    k.. so, tell me where you not able to off the TV from the remote or TV.
    k..
    download manual from---
    http://www.retrevo.com/support/SpectronI...
Lg 42" tv not displaying screen image
The t-con board controls the picture. To test it shine a flash light on the screen abd see if you can see an image when the TV is on. If you do then the T-con board is OK. Look at the back light ballast board (sometimes is part of the power supply board) If you see no movement or a dim picture with the flash light, then the T-con board is gone. You can get parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 11, 2016 | LG Televison & Video
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
I don"t know how to put my blue tooth in discoverable mode
Try this:
1. With your headset turned on, simultaneously
press the listen volume adjust button marked
+ (volume up) and the call control button.
Release the buttons when the indicator light
begins to flash red then blue.
2. While the headset is flashing red and blue,
use the phone menu to search for Bluetooth
devices and select "510 Plantronics".
3. When prompted for password, enter 0000.
The headset will flash blue when paired
successfully.
Don't forget to rate if this was helpful :-)
Sep 19, 2010 | Plantronics Explorer 230 Bluetooth Headset
Volume control doesn't work on Grundig t 55-640
Some TV has a hotel mode, try checking in Menu maybe your TV is in Hotel mode thus preventing you to maximize the sound or volume.
Jun 01, 2009 | Zenith A25A23W 25" TV
Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Nov 27, 2008 | JVC LT-42X579 42 in. LCD TV
Westinghouse lcd tv parts
Check this LINK to see if they have any available parts.
Feb 26, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a new Philips tv that did the same thing on me I left it off for a couple of minutes and that seems to work
Dec 27, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Protron PLTV-32 Television Logo
18 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
