Question about Nikon D50 Digital Camera
Nikon D50 - clock and battery icons blinking
LCD does not work and sd card icon (with slash through it) is shown through viewfinder. Camera turns on and focuses, but cannot see menu or take pictures...tried reset, new battery and SD card swapped with dad's d50...his batt and sd did not work. There is another post out there, which has not been answered. Can anyone help?
Performed "green dots" reset...nothing
Performed "menu" reset....nothing
Performed "factory settings" reset on bottom of camera...nothing.
5 others have the same problem posted on this website with no solution. Any ideas?
  • 3 more comments
  • Anonymous Jan 05, 2009
    Exact same problem
  • happydad Jan 07, 2009
    I have the exact same problem after dropping my camera from an accidentally unclosed camera bag. It was about a 4 foot drop onto packed snow. I can't believe the D50 is that fragile.
  • Anonymous Jan 28, 2009
    Exactly same problem. Battery icon flashing, slash through SD card icon. No menu. Will not reset. The camera just suddenly stopped working.
  • Anonymous Feb 21, 2009
    Similar problem with my Nikon D50. Suddenly stopped working. No LCD display. Slash through SD card. Battery blinking. No menu. Tried reset. Told it was a "catastrophic failure". Sent it to Nikon UK who estimated repair at £138 + VAT.
  • Alonzo G. Jan 04, 2012
    Similar problem. Low Battery icon flashes through viewfinder and on top. I charge my battery to full, throw it in the D50, and it says it's low battery, throw it back on the charger and it needs to be charged again? repeat same thing. Not sure what the solution is.
Hi
I had the same problem and rectified it by going to Nikons website , follow this link for the answer:
http://nikoneurope-en.custhelp.com/app/answers/detail/a_id/10601/p/19%2C244/c/241/kw/Clock/r_id/127673
Posted on Mar 26, 2010
  • aaronruggles
    aaronruggles Jul 22, 2012
    It would have been but it has been taken down. Any other sources, reprints, etc???? Can you share the fix on the short form???
  • Saurabh Bakshi
    Saurabh Bakshi Mar 12, 2017
    Did anyone get access to this now-dead webpage?
My LCD monitor won't light up to take a picture but it does when I review those I have taken thru the viewfinder
Most screens can be turned off for low battery usage. Check battery with tester or have it tested or replace battery and check menu and see if review screen is turned off. Rich
Apr 02, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
Tip
My S21S has a blank viewfinder, other than the menu and the ability to view...
I use the hacked firmware 2 years ago. Then Custom Function (12) has been set for Mirror Lock-Up = [On]. Mirror Lock-Up only applys on Single Drive and Timer/Remote but not Continuous Drive mode. So I set to Continuous during normal use and immediately set to Single Drive mode for MUL for some shots that need it, e.g. long tele-lens in dim lights.
on Apr 10, 2008 | Canon Digital Rebel / EOS-300D Digital...
I need to format my scan disk data card using my camera
I assume by "scan disk data card" you actually mean a SanDisk brand card.
Press the [MENU] button. Select Setup (wrench icon). Select "Format memory/Format card" (camera-slash-card icon).
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. Make sure the card is unlocked before putting it into the camera.
If you need a manual, you can download one from here. Setup menu instructions begin on page 85, formatting instructions are on page 100.
Nov 29, 2011 | Nikon Coolpix L22 Digital Camera
I can view my photos on the LCD viewfinder but can not transfer them from the SD card to my PC. The software from the CD has been reloaded but no change. Any ideas?
plug in camera USB.. go to start control panel... locate the scanners and cameras icon ... click on it to open it look for camera.. investigate in the folders until you fond pictures
Oct 09, 2009 | Samsung Digimax S600 Digital Camera
two things here, have you checked to see if the location to store the pics if it is placed to the intenal memory and the memory is full
also pls try to take a pic with another SD card may be that this card is either corrupted or damaged
Jul 23, 2009 | Nikon D50 Digital Camera
Canon S2 IS problem blank viewfinder and LCD
some cameras have the choice to take the picture by looking through the veiwfinder or on the LCD screen. check in the menu and set it to LCD if you want to use the LCD
Mar 21, 2009 | Canon PowerShot S2 IS Digital Camera
Canon 1000D wont let me shoot
It can be the cold or wet. try to keep it in dry place and change the battery.
Feb 04, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Camera only allows 7 pic's to be taken
If your SD card is more than 512mb the Kodak C340 will not read it. I had the same problem. I tryed to use a 1gb and it would not work and I also had the camera icon in the corner......You did not hit anything wrong......Try a smaller than 1gb sd card.......Hope this helped :)
Aug 31, 2008 | Kodak EasyShare C340 Digital Camera
Rebel XT - LCD monitor.
The camera is a Single Lens Reflex (SLR). It is not possible to use the LCD display as a viewfinder. See Canon's answer here: CanonUSA
Jan 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
No image on lcd
This is not a problem. This is how the camera is designed to work. It is an SLR and you must view the picture you are taking through the small viewfinder not the LCD. It simply reflects the camera settings,etc. I too was thinking it was a "viewfinder" and a bit disappointed that it wasn't. Oh well.
Jan 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Nikon D50 Digital Camera Logo
2,087 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
