Question about Whirlpool GBD307PDS Electric Double Oven
The baker is not coming on
The oven is not coming on because of a power surge it knock the circuit board out of use
  • 76 Answers
If you know you have the proper voltage to the unit (gas 120v), electric(220V) then you will have to replace the board
Posted on Jan 01, 2009
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 | GE Ovens
My oven is about 10-15 years old and I cannot reset the clock after the power has been disconnected.
Hello. I need the model number to help you accurately and provide part numbers for your particular unit. Was the power turned off by you or was it a power outage(caused by lightning, construction, etc). If the power went out due to an outage, the main board might very well have been damaged. Power interruptions are notorious for blowing out or damaging circuit boards in ovens, microwaves, dishwashers, washers, dryers...the list is almost endless. Normally, the power going out doesn't do the damage--it's the restoring of the power(and the accompanying current surge) that is the culprit. If a board has been damaged by a current surge, if it wasn't knocked out completely immediately, 3-4 weeks after the event is the usual time when symptoms start appearing--caused by weakened electronic chips on the circuit boards starting to fail.
Sep 18, 2015 | Fisher and Paykel Ovens
++thermal fuse location
Wiring verified correctly? Or could be a dud from the factory.
Mar 03, 2014 | GE Ovens
Jenn air svd46800 oven not working
Good Afternoon,
The control boards in your appliance may have failed. There is a display board, part number 71001799 and relay board part number 12001693. Commonly we see transformers on these relay boards fail with power surges. Luckily, we do test and repair these parts. Remanufacturing these controls will save you the high cost of buying new, and each rebuild will come with a 2 year warranty-- which is three times longer than new. Email me if you have any questions! info@fixyourboard.com
Jun 05, 2017 | Jenn-Air Ovens
No power
you need to check the main circuit breaker in the house and make sure it is not tripped.
the check the main wiring harness connected to the back and insure all your wires are conneced properly.if you have had any kind of power surge the your main control board may have suffered a fatal short.you need to look at the control board and look for any discoloration on the boards circuits.
Feb 01, 2010 | Frigidaire 27 in. Electric Double...
I have a ' Firenzi ' electric oven which has ceased to function after a recent power cut. The word ' STOP ' appears on the display. Can you help? Regards Norman Dayton
HI. This will occur when a surge has entered the unit, due to the power outage. Normally, there will be a power surge when the power is re-introduced to the home circuits after a brief outage. This will damage most unprotected electronics in this situation. The most vulnerable area in the unit will be the main control board. I would advise to try a hard rest. You can initiate this by simply shutting down the appropriate circuit breaker, or unplugging the unit for 5 minutes. Once the 5 minutes have passed, kindly re- introduce power to the unit, and try to run a baking cycle. If the word stop, or PF illuminates on the display, this will confirm that the surge has damaged the board. It must be replaced, in this case.
Nov 13, 2009 | Ovens
Keypad/clock went blank
Normally when a power surge lands a direct hit on a non protected circuit board, it will usually fry it completely. you can confirm this by shutting down the power for 5 minutes. if the control doesn't respond after the 5 minutes of no power, this will confirm circuit failure due to the surge and, you will need to replace the board in this case.
May 18, 2009 | Maytag CWE5800A Electric Double Oven
LCD display is blank , won't light up at all?
I had the same problem, mine faded out over time until I couldn't read it anymore. I had to have the circuit board replaced. The technician said that over time voltage surges can burn them out. It used to be frequent that I'd come home and all the clocks needed to be reset, so I know my area does have power problems.
The board comes out rather simply, I'd do it myself if if ever happened again.
Feb 10, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Whirlpool GBD307PDS Electric Double Oven Logo
162 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
