Question about Comfort-Aire PAC-121 Air Conditioner
Need a manual
I am actually looking for a manual for a Comfort Aire PAD121
  • Anonymous Feb 04, 2009
    need a manual for pad 121
Looking 4 manual 4 comfort aire a.c. model#pe-121a serial# 070301060
Posted on Jul 24, 2010
I have a comfort aire pac-121 and the display is reading e4 and the ac is not working. i can't find a manual on line. How can I fix the problem? thanks andy
I have the same model, though several years old, and on mine E4 simply means the reservoir is full. Try emptying the reservoir tank and then turning the power on again. If the drain hose outlet isn't angled down, the water drains into the tank, which will need to be emptied regularly. (For constant use, may need to be emptied several times a day.)
Jan 15, 2011 | Comfort-Aire PAC-121 Air Conditioner
Fan speed button on window air conditioner
This is mot my field of expertise, in any case here is the user manual. Hope it can help
Feb 25, 2008 | Comfort-Aire EKTC12-150J Air Conditioner
B zone is only cooling to 49 degrees and leds at L3 and L4 are blinking at 1 second intervals at circuit card on outdoor condensing unit. Is there a service manual available for download?
Hi
The L3 and L4 lights are blinking means that the filter is dirty and obstructed. You’ll need to clean the filter. Also Inspect whether the evaporator air is blocked, remove the blockage. Check the air intake and outlet ducts of the condenser side are obstructed. Check both of the ducts. Check whether the unit is set on dehumidifying mode. Set at cooling mode, Set at low fan speed Re-set the fan speed at high speed and check.
However, if this doesn't help then it might have happened that the compressor is not runing and the connection to the compressor is cut. Please check the wiring diagram on Pg 22 in this manual---
Comfort-Aire Air Conditioner Manual & wiring diagram
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Aug 02, 2010 | Comfort-Aire HMC18AD-1 Air Conditioner
Remote control for Comfort Aire AC Model # RAD-81C
If you need a remote for your ac unit go to ebay. You can get a universal remote for your unit. Russ
Mar 23, 2010 | Comfort-Aire RAD-81 Air Conditioner
Comfort aire overtemperature switch part no. 47-21900-01 I am looking for this part. thanks stew
Call Heat Controller in Tennesse they distribute this although it is made by LG
Jan 22, 2010 | Comfort-Aire BHD-501 Dehumidifier
Comfort-aire dehumidifier 501 cycles on and off
It is possible that the humidity is below the set point of the dehumidifier. They will run for a short time until they get a true fix on the actual humidity then shut down.
Jun 28, 2008 | Comfort-Aire Dehumidifiers
Comfort aire A/C Rads 101-A EE light
Possible faulty control electronics. Call a repairman.
May 28, 2007 | Comfort-Aire RADS-151 Air Conditioner
Comfort-Aire PAC-121 Air Conditioner Logo
667 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Cesar Quant
Cesar Quant
Ottoniel
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
