Question about HP Photosmart 850 Digital Camera
HP Photosmart 850 digital camera
Flash no longer works. Can it be fixed
Connect the camera. Remove the batteries, without touching the upper buttons.Let it open 30 min or more. Then put the batteries, and restart the camera. This worked in my case
Posted on Jan 16, 2009
How do I remove the lens of a HP Photosmart 850 Camera?
Repairing camera is a specialty. so unless you have this skill you'll have to let someone else fix it. i sent my camera to be fixed to: www.camerarepair.com they were reasonably priced and have a 6 month warranty. they're pretty quick also.
Jan 03, 2010 | HP Photosmart 850 Digital Camera
Flash not working
Assuming that you haven't put the camera into a mode in which flash is disabled, either the charging capacitor or flash bulb is defective. It will have to be serviced so the appropriate part can be replaced.
Dec 03, 2007 | HP Photosmart 850 Digital Camera
No flash in any mode
Either the flash tube or the charging circuit/capacitor have failed.
There is no realistic fix: the camera is around five years old and no longer supported by HP so original parts are not available. Generic parts may well do the job but will cost more to buy and fit than you'll pay to replace your camera with a good used example and if you fit them and they don't work then you'll have wasted your money. If they do work then the camera will need re-calibrating to the flash output which will be different to the original parts, this needs special servicing software which HP never released freely.
Sorry to disappoint you, but when you can replace your model with the superb Sony DSC-V1 in excellent full working order for under £30 it makes any kind of repair attempt to your model non-viable. The PhotoSmart 733 is near worthless second-hand, so you won't often see them for sale.
I hope that you've still found my posting to be of some use and ask only that you return the favour by rating my answer.
Nov 02, 2009 | HP Photosmart 733 Digital Camera
When using the flash, camera shows charging flash and freezes up the camera
I contacted HP tech, after trying several resets and other setting changes, I was informed that it would cost more to fix the camera then its worth - No longer under warnaty.
I can use the camera as long as I disable the flash.
Go out a buy a Canon, I did and its a lot better camera.
Aug 04, 2008 | HP Photosmart 735 Digital Camera
Flash no longer works, can this be repaired?
But a 2nd hand camera and replace the old one straight out.....
No hot shoe unfortunately for an external flash!!!!
Jun 15, 2008 | HP Photosmart 850 Digital Camera
Flash won't fire
charging flash:-
POSSIBLE CAUSE:The camera is recharging the flash.
SOLUTION:It takes longer to charge the flash when the battery is low. If this message appears a lot, replace or recharge the battery.
Dec 28, 2007 | HP Photosmart R607 Digital Camera
HP R727 stays on 2 seconds then flashes contact HP
Try holding in the reset button longer then the recommended 6 seconds.
I've fixed many of these Photosmart series this way.
Dagra
Dec 20, 2007 | HP Photosmart R727 Digital Camera
Broken Battery Door
I have the same hp 850, No way to fix it, So to hold the Battery Door Down, I Drill'ed a small hole through the top. & through the case
where, the camera latch Broke, & do it Real Slow..... Put a Sheetmetal Screw in the hole i drilled & it Work's Find. Just do it SLOW<<<<<<<< Good Luck & it's up to You What size to use
So Think it Over before you Try it....Slow slow slow, & the right size Drillbit,screw, & turn it in Slow.. P.S. It was do that! or $500
Down the Drain, Good Luck, The Wizard
Dec 15, 2007 | HP Photosmart 850 Digital Camera
CAMERA IS NOT FLASHING
The camera is recharging the flash. (possible cause)
Solution: It takes longer to charge the flash when the battery is low. If you see this message alot, you may need to replace or recharge the battery. Hope this helps!
Nov 27, 2007 | HP Photosmart M407 Digital Camera
Can i use a power cord and not use batteries?
The camera will work with the charger cord plugged in, but you are limited to taking photos only near a power source. I have the same issue; broken battery door...Still looking for another hard broke 850 to take parts off of.
Sep 29, 2007 | HP Photosmart 850 Digital Camera
HP Photosmart 850 Digital Camera Logo
158 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
