Question about Samsung HT-TZ515T Theater System with Wireless Speakers
Rear Chk Message
Hi, I've followed your instructions on how to reset the connection by holding the remain button, however it doesn't work, nothing lights up. I've done it with the unit on,off, even unplugged! for up to a minute with no flash of a light of the volume or the power indicator. Im using a HT-TZ315 with the SWA-3000.
Was wondering if you would have any idea why it wouldn't work. Thankyou.
Regards
Chad
5 Suggested Answers
SOURCE: Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
Posted on Nov 09, 2008
SOURCE: SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit 2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc. 3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash. 4.) Point the system's remote control at the Head Unit and punch in 0135.  Its light should turn from red to blue. 5.) Perform step 3 again. 6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
Posted on Apr 30, 2009
SOURCE: Speakers won't connect
Here is a link to Samsung's HT-Z510 Home Theater rear speaker troubleshooting guide.
http://www.samsung.com/us/support/popup/howToGuidePopup.do?howto_guide_seq=629&type=hometheater&subtype=hometheatersystems
It has worked for me after a couple tries. Good Luck!
Posted on May 10, 2009
chipsandnuts
  • 70 Answers
SOURCE: Hi, I have Samsung HT-X50 connected with SWA-4000.
You have to reset the connection:
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Posted on Jul 03, 2009
chipsandnuts
  • 70 Answers
SOURCE: i'm having problems getting my swa-4000 system to
Hope this helps!
How to clear memory on HP P3015
Before starting, note down the IP address if its network printer..
1. Turn the product off.
2. Turn the product on. When the memory count begins, press and hold the OK button. Continue holding down the OK button until all three product control-panel lights flash once and then remain on. This might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the button or the button until COLD RESET is highlighted.
4. Press the OK button. The product performs a cold reset and then continues its power-on sequence.
5.Chk & set I/O settings..if required..
Jul 31, 2015 | HP LaserJet Office Equipment & Supplies
How do I reset the lamp meter? I don't have the remote control.
NOTE: If the "Please Replace Lamp" message is displayed, press [RETURN] or [EXIT] on the remote to remove the message.
1. Turn the unit ON.
2. Hold in the [VOL-] button on the front panel and simultaneously hold down the [RECALL] button on the remote control. After 3 seconds, a red "CHK" appears on the screen's left corner. If a solid color screen appears, press the Recall button repeatedly until "CHK" reappears.
3. From within the service mode, hold in the [VOL-] button on the front panel and simultaneously hold down the [MUTE] button on the remote control. Continue to hold (approx. 3 seconds) until the lamp time resets to zeros.
Mar 05, 2015 | Televison & Video
How do I reset lamp? I don't have the remote control.
Have a canon printer (i9900) & the message I'm getting: "waste ink absorber is almost full". What does this mean & what do I do?
Hi
This is a regular maintenance required you to take the printer to service centre to replace the ink-pad present in the printer. Follow the below instruction to keep working with the printer as normal.
First of all remember that these measures are then by the company for protection of ink overflow.
If you can spare some time try to take the ink pads out of the printer and wash them thoroughly so no ink remains in them and then do the below instructions.
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The indicator will blink in green and remain in green.
3) Press resume button 4 times (Green) for Waste ink counter reset.
4) press the power button. The printer will switch itself off after performing the function.
Then you are ready with the printer to work.
PLEASE RATE MY SOLUTION
THANKS
Jun 29, 2011 | Office Equipment & Supplies
I have a TI84 plus texas instruments i have removed both the batteries in order to reset the unit but it still has not resetted the unit. All I am getting all zeros on the screen
First try removing all four AAA batteries and the small lithium backup battery (above the four AAA batteries). Leave all batteries out for five minutes, then replace them and try to start the calculator. If this doesn't work...
Replace all but 1 AAA battery. Press and hold the "CLEAR" button on the calculator. While holding the "CLEAR" button down, replace the missing AAA battery. While still holding the "CLEAR" button, turn the calculator on. The display should read "RAM Cleared". Release the "CLEAR" button and press again to remove the message.
If that doesn't work, remove 1 AAA battery again. Repeat the preceding instructions with the "DEL" key: With the battery removed, press and hold the "DEL" key. With the "DEL" key held down, replace the battery and turn the calculator on. The screen should say "Waiting... Please install calculator software now." Release the "DEL" key. Download this program onto your computer (from Texas Instruments). Connect the calculator to the computer using the USB cable provided with purchase. Run the TI OSDownloader program and follow the on-screen instructions to re-install the calculator's operating system.
Apr 30, 2011 | Texas Instruments TI-84 Plus Calculator
How do I auto set up for my zoooos controller
Auto Setup automatically searches for the right code for your DVD player. For the most popular DVD player models, Auto-Setup takes a few minutes or less, however, less-common models can take much longer or this method may not work at all.
  1. Find the Auto-Setup instruction page in the on-screen Setup Guide. Your DVD player must be on the Auto-Setup instructions for this method to work properly.
  1. Engage Auto-Setup mode: Hold down the Red button until the setup light turns off. Continue holding the Red button and press the Yellow button three times, then release both buttons. If you’ve done this correctly the light will turn back on and remain on until setup mode is exited. When the setup light remains on, the controller is in setup mode.
  1. Wait for a message from your DVD player. Even though you can’t see anything happening, the controller is actually loading and testing various codes. When the right code is found, your DVD player will tell you to press the Home button. If your player doesn’t respond within about 10 Minutes or the time on the estimate chart, press the Home button to exit this method, and use the Direct Entry method instead.
  1. When the DVD player instructs you to press the Home button, be sure to do so before the onscreen timer runs out. If you miss pressing the Home button before the timer runs out, go ahead and wait until a message from the DVD tells you what to do. If you have not yet pressed the Home button, the DVD will instruct you to press the Back button to back up to the code you missed.
Jan 09, 2010 | Fun Rise Zoooos DVD System
Samsung HT-TZ315 Holding "REMAIN" Button
Can you help me, please ?
I have a problem with my samsung. On my screen write "FUN CHK" and I can do anything and in the moment my samsung is turn off. I have read guarantee but I could't find this problem.
Thank You !
Aug 03, 2008 | Audio Players & Recorders
Rear Wirelss speaker do not work
With the main unit turned off, press and hold [REMAIN] on the home theater's remote for 4 seconds. (The REMAIN button is directly under the 7 button). Once held down for 4 seconds, the Volume Indicator on the main unit will turn on for 1 second. Release the [REMAIN].
Press the [RESET] on the back of the Wireless Receiver 2-3 times. The Standby/On LED on the front of the Wireless Receiver will blink 3 times
Turn on the main unit. The Link LED on the wireless receiver will light up if process is done correctly. The front of the main unit will no longer say REAR CHK and the rear speakers should now function correctly.
Feb 24, 2008 | Samsung HT-WX70 Theater System
Resetting lamp panasonic PT40LC12
Press the power button to turn the unit on.
While pressing the Vol-(volume down) button on the projection display,
hold down the PIP button on the remote control at the same time for more
than 5 seconds. When the reset procedure is complete the following message
will appear on the screen. "Lamp time was reset to 0".
Jan 06, 2008 | Panasonic PT-40LC12 40" Rear Projection...
PHONE NOT TURNING ON
Did you try removing the battery from the phone overnight?
If that doesn;t work try a hard reset (assuming you can't access soft reset - code *#7370#).
Here is how you do a hard reset.
  1. Switch off the phone.
  2. Hold down the following three buttons: Green (call answer) button, * button, and '3' button
  3. While holding these buttons, press the power button and switch on the phone
  4. When the message 'Formatting' appears on the screen, release all of the buttons
Dec 15, 2007 | Nokia 6600
Samsung HT-TZ515T Theater System with Wireless Speakers Logo
130 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
sonic boom...
sonic boom...
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
