Question about Chaintech Slot 1 CT-6BTM Motherboard
Wish Chaintech 6BTM to wake up from power back
I've been using an old computer (MB Chaintech 6BTM, ATX case) as an unsupported server. Everything is working OK except one thing: in case of a power failure, when power is up again, the system does not boot up expecting someone to press the button to start. I know that the modern mothherboards can be set up so that they automatically boot up on power back, but not my 6BTM. The 6BTM can wake up from keyboard, LAN, modem but not from utility power. How can I make it to start by just "plugging it in the outlet"? Thanks for any ideas.
  • Sergey Pankratov Apr 29, 2007
    Thank you, sandrew.
    I haven't set up the UPS setting in control panel as it only knows about the APC brand whereas my UPS is Powercom, and I have their proprietary software installed and set up.
    Unfortunately, both Powercom's software and the UPS option of Windows only guarantee smooth shutting down, they do not control system restart afterwards.
    My Powercom does have the Autostart feature (it switches itself on when AC is back) but it does not signal the computer when it is up again.
    Could you please clarify your second suggestion, I mean wringing "+" and "-" round?
    The two wires belonging to the Soft Power Connector group are marked as PW+ and PW- indeed. But those wires lead to just a mechanical switch on the front panel.
    To the best of my knowledge, exchanging "+' and "-" wouldn't make any sense in this case.
    Or maybe I got something wrong?
    Thanks again.
    President:
  • 2,961 Answers
It may be a setting called ups in control panel>power options and make sure ups is enabled and set up correctly. The only other way to do it is from the power connectors on the motherboard from the front panel, if you get the + and - the wring way round it will make the pc turn on without the use of the button
Posted on Apr 29, 2007
  • andrew pester
    andrew pester Apr 29, 2007
    it's a bit hit and miss but if you mess around with the pwr+ and pr- or leave them off you should be able to make the pc switch on and off only via the wall plug and not the front button, i know because in the past i have wired them wrong by accident and it would power on the pc without the button and only switch off at the wall
I want to know how connect the power led sw ,reset sw,hdd ledand my mother board is a chain 7AIA5 I DONT HAVE THE MANUAL I WOULD LIKE TO GET ONE PLS. THANKYOU
Chaintech supposedly has an ftp server with their old stuff on it, but it wasn't working for me. I found this obscure ftp site that does actually have all the manuals on it though:
ftp://ftp.jet.lv/Manual/Chaintech/
They are all self-extracting archives but I would recommend using 7-zip or another zip program to extract the files.
Dec 23, 2009 | Chaintech CT-7AIA Motherboard
Iam interested in up-grading to a new mother board, and or wondering about what parts would be compatible to do so!
This depends upon how old the desktop computer is, if is more than say 5 years old then the power supply may not have the the right ATX power connector for the new motherboard (ATX2 has 24 pins, ATX has 20 pins). I would get a new hard drive they do fail with age.
You could reuse the CD/DVD drive, plus the graphic card, and sound card if it is not part of the motherboard, also the monitor, keyboard, mouse (but these are low cost items)
Basically by the time you strip everything out of the case and put in new components, you would be better getting a new computer.
Then remove your data from the hard drive and sell the computer or network it to your new computer and use it as a backup file server.
Nov 08, 2009 | Gigabyte GA-8I865GME-775-RH Motherboard
I need to know where i can find a manual,
Not listed but you can request info from them here..
http://www.chaintech.com.tw/a32_contact_support.php
they don't list this at their website
Oct 23, 2009 | Chaintech : SPT800 P4...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
No sound after re install win 98
Get the drivers disk ready for you win98 hardware (or download from website)
I bet you have to uninstall the sound card from device manager first and the restart the computer. Then try to install the sound driver again. If that does not work you may have to force install the driver from the add new hardware wizard in control panel.
that should get the sound card installed.
Jul 07, 2009 | Chaintech Slot 1 CT-6BTM Motherboard
Compaq 120694-101 Motherboard would like to totally upgrade
Your PC case will hold any atx motherboard with 4 or less expansion slots. Just about everything made now will fit. You will have to replace your power supply if it still has the standard factory unit installed. The newer boards require an ATX power supply with the additional 4 pin plug for extra power to the CPU. Go to newegg and look for combo deals, they run them all the time. Here is a gigabyte board that is very nice. GIGABYTE GA-MA78GM-US2H Micro ATX AMD Motherboard image-3300643-10440897
I hope this solution helps you out.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 18, 2009 | Compaq 120694-101 Motherboard
No manual for my chaintech spt800 motherboard
I have a manual. Somehow, I managed to keep track of it.
Contact me at storm5510@gmail.com.
Mar 10, 2009 | Chaintech : SPT800 P4...
Chaintech Slot 1 CT-6BTM Motherboard Logo
246 people viewed this question
Top Chaintech Computers & Internet Experts
Alun Cox
Pierre Legault
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
