Washer does not go clockwise
My wacomat front load washer does not go clockwise. It stop about 10 seconds and go anti-clockwise. I can hear the relay working. But motor does not run.
  • 15,935 Answers
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
The pump will operate for 5 to 10 seconds and stop. 2 or 3 minutes later it will pump again for a few seconds. It takes a long time to drain the machine.
Drain the machine. Then turn power is off at the wall socket. Then tip machine back against the wall as far as you can. Get down under front right of machine & remove the wires going to the drain pump. Next remove the drain pump by turning it 90 deg clockwise. There is a white clip near the top edge of pump on R.H. side - hold that out while you turn it. Once it is out check pump & up in the pump outlet hole for obstructions. Put pump back with wiring plug facing R.H.side of cabinet then rotate 90 deg anti clockwise. Re attach wires and stand machine up.
Jan 04, 2016 | Fisher and Paykel GWL11 Top Load Washer
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
My washer will fill with water but it will not rotate
the clicking of your machine is the drum rotation clockwise /anti clockwise the main problem is most likely the motor brushes worn depending on make of machine to how to remove and replace
May 12, 2012 | Malber P21 Front Load Washer
Spin cycle has stopped working...
If you have not already done so, then check the pump filter.
This should be behind a drop down flap at the bottom front right of washer.Unscrew anti-clockwise to remove.
If pump and filter o/k, then the next step is to check the brushes for wear in the motor, change if less than 3 or 4mm long.
Jan 10, 2010 | Zanussi FJS1225W Front Load Washer
Machine stopped mid cycle, have removed clothing from it but can't persuade it to drain water out. have no manual, any suggestions?
There should be a filter located at the bottom front right of washer behind a drop down cover or panel.
Unscrew anti-clockwise to remove and clean.
Hope this helps.
Jan 09, 2010 | Bosch Exxcel WFX 145S Front Load Washer
Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Dec 31, 2009 | Zanussi ZWF1230W Front Load Washer
Washer takes longer than it should to complete cycle, seems to add minutes. at end, clothes are very wet and i have to do 10 minute spin cycle just to get water out
I would recommend that you clean the pump filter.
This is usually located at the bottom right front of washer.
To clean unscrew anti-clockwise to remove and clean.
You may have to remove a plastic cover at bottom of washer to reveal the filter.
Hope this helps.
Dec 08, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
My GE Wizard Washer will agitate or spin for a very short time.
replace the transmission. this job is better done after a few dozen bottle of your favorite whiskey. Check the timer controls to ensure timer is advancing properly. tranny's are notorious on ge's for this sort of problem as well as inner basket drive blocks coming loose. ge makes alot of great appliances, this just happens to be one of them that isn't. i trust their jet engines too, although hard to work on them from 30,000ft.
Jul 02, 2009 | GE WBSR3140DW Top Load Washer
Hotpoint Washing Machine (W540) stopped working, LEDs flash....?
You must get the filter out, as there is a very good chance that this is the prob, keep unscrewing it and try to move it about, then screw it back in again , and then out again, hopefully this will dislodge whatever it is that is holding the filtter in.
Plz rate thiese comments.
Thanks.
Dec 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
