Question about BellSouth Lands Phones
Putting numbers into the memory for speed dialing
We have a BellSouth 227V phone and need to program some numbers into the memory for speed dialing. Can you provide directions or direct me to a manual on line?
5 Suggested Answers
SOURCE: Programming the "Memory Dialer"
You may try this: 1. Pick up the handset and listen for a dial tone. 2. Press and release the STORE button. 3. Enter the phone number(up to 16 digits)you want to store into memory(The telephone number will not dial out) 4. Press and release the STORE button. 5. Press a one-digit number(0 - 9)on the keypad to store the phone number into the desired memory location. 6. Hang up the phone by returning the handset to the handset cradle on the base. 7. To store more phone numbers in memory, repeat steps 1 - 6 Good Luck !!
Posted on Jul 19, 2007
SOURCE: Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Posted on Nov 29, 2008
SOURCE: uniden power max 5.8 speed dial
Press and hold a number key (0-9) associated with the speed dial until the phone number appears, and then press talk/flash or speaker on the handset or speaker on the base. The number stored in the speed dial is dialed.
Posted on Jan 22, 2009
  • 63 Answers
SOURCE: Programming speed dial numbers into NEC DTU-32D-1A phone
hit feature key,hit a line key,dial 9 plus the number,hit feature
Posted on Mar 14, 2009
consultel1
  • 860 Answers
SOURCE: How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Posted on Apr 16, 2010
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
Why does vtech not have a speed dial? my son is
Programming Speed Dial Numbers
The handset must be OFF.
1. Press PROG. The IN USE LED will blink to indicate that you are in the programming mode.
2. Press the number of the memory location you wish to store the number in (0-9).
3. Using the dial pad, dial the number you want to store. The number can be up to 16 digits long. The number can be entered manually or by using REDIAL.
4. Press MEM to store the phone number
to the key you selected.
The phone now exits PROG mode and emits a tone.
Speed Number Dialing
1. Press PHONE to get a dial tone.
2. Press MEM and the memory location number key (0-9). For example, to dial the number you assigned to key '8', you would press PHONE, MEM, 8
May 27, 2011 | Vtech 9009111 Cordless Phone
Meridian norstar want to delete and enter new numbers
If you are asking about Outside Auto Dial numbers (a "speed dial" number programmed to a button), follow these steps:
1. Leave the handset down
2. Dial "Feature (star) 1"
3. Press the button to be programmed
4. Enter the "speed dial" number
5. Press button under "OK" on the horizontal display.
The group of 12 buttons on top of an M7310 phone are Dual-Memory buttons, each can hold 2 speed dial numbers. When you press the button, you are using the Lower Memory location. When you press the Shift button (triangle-shaped button on the right) and the a Dual-Memory button, you are using the Upper Memory location. Good Luck!
Sep 28, 2009 | NorStar Meridian M7310 Phone
STEPS NEEDED TO PROGRAM SPEED DIAL
For speed dial go to Main Menu >> settings >> initial setup >> Speed dial >> Phone Memory.
Than transfer numbers which you want to assign as speed dial in Phone memory.
Goto particular contact and edit the number and assign it as Speed dial.
May 20, 2009 | Motorola Mobility RAZR V3
Programmed speed dial - internal calls
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
Jan 19, 2009 | Siemens optiPoint 500 Standard Corded...
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
needed.
own memory!
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
How to proram speed dial
Here is the solution:
1) Pick up the handset
2) Press the "Store" button
3) Dial the number that you want to store
4) Press the "Store" button
5) Press one of the Memory button such as M1, M2, etc.
6) hang up the phone (put the handset back to the base)
When you're ready to dial the number, just pick up the handset and press one of the Memory button that you just use to store your desired number.
Best of luck,
KP
Dec 18, 2007 | Sakar Talking Caller-ID Speaker Phone
Uniden 900MHz phone model EX17960A
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
Nov 13, 2007 | Lands Phones
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
STORING A NUMBER IN MEMORY
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
CHANGING A STORED NUMBER
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Apr 27, 2007 | GE 29318GE1 Corded Phone
Lands Phones Logo
83 people viewed this question
Top BellSouth Lands Phones Experts
Are you a BellSouth Lands Phone Expert? Answer questions, earn points and help others
