Question about RIM BlackBerry Pearl 8100
Blackberry pearl turns off when i touch the rollerball
My blackberry pearl turns off/restarts (its different every time) when i move the rollerball to scroll.  I can see all of my texts and contacts but i cannot read any messages because the phone turns off when i scroll. help!
  • 367 Answers
Try a different ball in the device they are fairly easy to remove. Borrow a friends entire track ball use nail file to remove the ring then look to make sure what way the mechanism and ring go back in and try your firends if his/hers works in your phone replace the defective part. blackberry pearl turns off when i touch the roller - 2b4daea.jpg eb3c8be.jpg
Posted on Jan 02, 2009
Roller ball on blackberry won't work
Was it Like it when you bought it?? If not, then its probably broken.. it happens a lot with rollerballs.. if you take it back to the shop you bought it from they will probably send it away to be fixed.
Sep 05, 2009 | RIM BlackBerry Pearl 8100
My Rollerball won't scroll down - tried everything.
Cause: The sensitivity of the trackball/trackwheel might be less Faulty Hardware Resolution: Increase the sensitivity by following procedure Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100 If not working check with the service center
Aug 11, 2009 | RIM BlackBerry Pearl 8100
Rollerball assembly help
this link tells you how to put it back in the correct way...
very good explanation includes pictures
May 04, 2009 | RIM BlackBerry Pearl 8100
Rollerball of my blackberry8100 is nt working
Use Rubbing Alchohol on a Q-tip to clean the roller. This happens to me all of the time and this always solves the problem
Jan 28, 2009 | RIM BlackBerry Pearl 8100
The rollerball on my blackberry pearl does not move down only up
Your rollerball needs a clean.
The silver ring which covers the trackball can easily be removed if you use a small screwdriver to lift it at the outer side of the ring. Be careful here! Like you should be during the whole process as all parts have very small plastic nipple which can break very easy. When the silver plastic ring is removed you will see the inner trackball component which can be removed completely. Before doing this you should carefully remove the silver metal ring that holds the trackball component in its position. The trackball component itself can also be carved. For every direction the ball can roll to you’ll find a sensor wheel. Those wheels are mostly carrying some gunk you should clean them from. Once this is done put everything back together to the place the pieces came from and secure the trackball with the silver plastic ring you removed in the first step. Your BlackBerry’s trackball should be back working now.
There are pictures of how to do this on "other" forums.
Dec 04, 2008 | RIM BlackBerry Pearl 8100
Blackberry Pearl enter's on by itself
Try updating your handset software:
Good luck and remember to backup your data before you do this!.
Rollerball Issues
Try cleaning the trackball. Use a q-tip dipped in IPA or rubbing alcohol and use it to rotate the ball around a few times. Try a few times to make sure it is clean.
Aug 25, 2008 | RIM BlackBerry Pearl 8100
Blackberry rollerball
Hi guys I have the solution. I think all your trackballs are stuck. If you cant move it, take the silver ring off with a knife, take off the trackball and put rubbing alcohol on it wth a Q - tip until it works. Can some1 help me? My problem is titled My blackberry pearl wont load up.
May 16, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
146 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
