Question about SanDisk 2GB microSD Memory Card
SanDisk 2GB Memory Card write-protection
Hope you can help me out with following problem. I just purchased a SanDisk 2GB Memory Card. I would like to upload photo's on this by copy/paste from my pictures. The disc reports write protection is on. I have switched the little switch on the side of the disc, so this is not the solution. can you please tell me how to switch write-protection off?
thanks
  • emmanuelhp12 Jan 02, 2009
    i bought a san disk microSD 2gb card for my motorola ve240.when i try putting music or pictures on my card by copy and pasting from my files it tells me write-protection is on.how can i take write protection off?
  • Tammy Looney May 11, 2010
    did you move the switch with the disc inside the adapter?
Hey I just figured this one out dont know if it is a cowinkydink or what but on the adapter the big one it has a little slide you wont see it unless you look for it, its on the leftside, it says lock one way and unlock is the other. So I switched it to unlock and it seems like its downloading, I havent got the error message about the write protection yet and its still downloading, Try that and see if it works, Im gonna try mine and see in about 4 minutes. Good Luck!
Posted on Apr 23, 2009
Plz help me to remove write protection from my micro sd card.
Hi, slide up the Write protection switch which is white in color for the Memory Card Adapter to remove Write protection and Slide down to enable write protection of the Memory Card.
Please click on the link below to view the Write protection switch:
http://kb.sandisk.com/euf/assets/images/faqs/id1102_e3sdhc.gif
If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Apr 16, 2011 | SanDisk 2GB microSD Memory Card
My sd card no farmate plz help me
You'll probably find a write protection switch on the side of the card. Just move the switch to the unlocked position (you probably moved it by accident). Then try formatting it will work.
Hope this helps.
Shane
Feb 16, 2011 | SanDisk 2GB microSD Memory Card
I forgot the password of my 2gb sandisk memory card
Unfortunately May be you should try Formatting it.
Hope this helps.
Cheers!!!!
Jan 03, 2011 | SanDisk 2GB microSD Memory Card
I am unable to format my memory card? i have purchased new sandisk 2GB micro sd memory card,but in few days this problem will occur
We Wish You a Happy New year.
Right Click on the Memory card and check for properties and see, if it is showing 1.85 gb then you need not format or try to format in FAT32 if you are using NTFS.
Hope this helps you. Cheers!!!
How can i remove the write protect in my memory card if it doesnt have a slidable lock
The procedure for removing the right protection is given in the website given below.
please follow the directions and you can remove it.
http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/
Thanx
Jul 20, 2010 | SanDisk 2GB microSD Memory Card
How I remove the writw-protection to the memory card
Hi!
In order to remove write-protection from the memory stick, connect it to the device in which write-protection was implemented on it then use the feature of the device to remove write-protection off the memory stick.
Should you require any clarification, you may write back.
Give a try!!!!!
Sep 16, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Formatting
Hello Laurakeeney1
I would check to make sure your SD card in not Set to Write Protected, if it is not follow this link for a Flash Memory format utility that I use to fix any problems i have with Flash memory
HP USB Disk Storage Format Tool - v2.1.8
http://files.extremeoverclocking.com/file.php?f=197
Hope this Helps
May 05, 2009 | SanDisk 2GB microSD Memory Card
Locked 2gb micro SanDisk Phone card, how do i unlock it?
SD cards and microSD adapters have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 26, 2009 | SanDisk 2GB microSD Memory Card
Card Error on a 4GB SDHC Sandisk Memory Card
I went onto the BestBuys site and found a link for compatible memory cards - The SanDisk SDHC isn't compatible with the Canon Poswershot SD750!! Only a 2GB card will work. The Lexar SD and the Kingston Technology 2GB will.
Dec 19, 2007 | SanDisk 4GB Secure Digital High Capacity...
SanDisk 2GB microSD Memory Card Logo
266 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
