Question about Braun Tassimo Espresso Machine/Coffee Maker
Lights keep flashing on my tassimo machine
The lights on my coffee machine keeps flashing am niot sure how to set it for a cup of coffee thanks
  • 2 more comments
  • plainandsimp Dec 30, 2008
    thank you very much trouble was i hadn't used it for so long i forgot how to thanks again
  • Anonymous Mar 20, 2014
    All lights flashing on machine
  • Anonymous Mar 23, 2014
    won't run
  • jascent king Jun 15, 2016
    The heating light stays on my tasimmocoffepod
If your lights are flashing on your mashine just keep your finger on the button untill its filter threw, willtake up to 2 mins. simon bernasconi
Posted on Oct 04, 2009
I tried all the solutions from giggling the resovoir to removing the filter. I was ready to give up and throw the coffee maker away when I read the posting about fooling the sensor with the magnet. it worked...!!!! Thank you very much.
Posted on Feb 10, 2012
  • anitaroberts
    anitaroberts Jun 24, 2017
    Where's the post about fooling Sensor wth a magnet?
Plainandsimp how did you fix your problem because i have the same one. thank you!
Posted on Aug 06, 2009
I know that if the water reservoir is empty or the reservoir isn't properly attached all the lights flash until I correct it. I think the first time I powered on my unit all the lights flashed as well but went away after I put a coffee disc in.
Posted on Dec 30, 2008
Somebody else on this program helped me with my problem thank you
Cuisinart coffee center, ss-15, lights are flashing on cup sizes, and won't make single cup coffee.what to do?
We have the Cuisinart combination 12 cup coffee maker with a 6,8,10 K-cup maker. Today 8/06/2017 the K-cup started making a strange sound stopped working and all 3 blue lights 6,8,10 where flashing and wouldn't make a cup of coffee. After some looking around it seemed that the top stainless steel water injector was clogged, I took a long toothpick and slowly pushed it in as I spun the toothpick around slowly as to not break the toothpick off inside, the water injector is sharp so the toothpick will fray as you spin it around inside this is why you must go very slowly. I also did the same to the K-cup holder stainless steel spike tube to make sure everything was clear and clean, I then ran 4 full water containers through the K-cup system starting with the 6, than 8 and 10 oz. size. I was finding little black objects in my 20oz drinking cup as I was doing this, not sure what that was but after running the 4 full containers through it they were gone. Now it works fine. I hope this helps anyone with the same machine having the same problem
Feb 13, 2017 | Cuisinart Coffee Makers & Espresso...
Can't set clock. 12:00 keeps flashing
SETTING THE CLOCK AND DELAY BREW TIME
To Set the Clock:
1.
Plug the power cord into a standard electrical outlet. The clock
will flash on the control panel to indicate that the time has not
been set yet.
2.
Press and hold the HOUR and MINUTE buttons until you reach
the current time. The AM or PM indicator will light at the bottom
of the display (Figure 1).
The clock is now set!
NOTE:
Pressing any button before setting the clock will cause the
clock to start keeping time from 12:00 a.m. You must set the clock
if you want to use the Delay Brew feature.
Nov 01, 2014 | Mr. Coffee 10-Cup OptimalBrew Thermal...
Both lights on my older model machine won't stop flashing
Try holding both buttons down while you turn on the machine - hold down till they stop flashing, usually 2 - 5 seconds. This resets the machine to its original factory settings.
Oct 11, 2014 | Nespresso Coffee Makers & Espresso...
PURCHASED B44 TODAY. CAN'T DO SET UP. PLUG IN, POWER UP, BOTH CUP AND MUG LIGHTS LIGHT UP (NOT FLASH) HEAT LIGHT FLASHES GOES OFF-TOP OF UNIT WARM. WATER DOES NOT TRANSFER TO UNIT. REALLY LOOKED FORWARD TO...
We just had the same problem with ours, and solved it by lifting up the grey handle to open the coffee maker, and closing it again. Not sure what the issue was, but this got the single cup light flashing the way the instructions said it should.
Dec 24, 2010 | Keurig Elite B40 Coffee Maker
How do I reset the machine to the 50ml/cup factory setting?
I have a similar problem that the 1 cup (50ml) setting now produces about 150ml and the two cup setting just keeps going until the machine is empty.
The manual says press and hold the 1 cup button until it starts flashing together with the power light and the coffee starts flowing, then press the 1 cup button again when you want it to stop and the machine will memorise the new setting. I tried this on mine and it didn't work - I'm guessing something has worn out but dunno what...
Jul 17, 2010 | Krups XP 4050 Espresso Machine
Small and large cup lights won't stop flashing
Tish3030 response worked PERFECTLY. Thank you, Tish.
Apr 19, 2010 | Nespresso Essenza C100 Espresso...
The on/off red light keeps flashing and won't work when pressed. I cannot get anything to happen. It won't turn off, won't make my coffee. It just keeps flashing
I have a Blender whose light flashes. Im not sure why? however, if you unplug for 10 mins starts up again. maybe you should try this
Feb 16, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
I've lost my manual for the Oster coffee maker model 3314-33 and the red "Clean" button keeps flashing after the coffee has brewed. Where can I download a manual so I can figure out how to fix this...
Pot needs cleaning. Fill reservoir with 4 cups of vinegar. Press the SELECT button until the red CLEAN indicator light turns on. Let it perk through. It will take 45-60 minutes. It brews a few cups, stops and then should brew the remainder of the vinegar. When the cycle is complete the light will burn off and the coffeemaker will turn off. Discard vinegar solution and run a couple of pots of clear water through. Hope this helps.
Aug 15, 2009 | Oster HDX23 12-Cup Coffee Maker
Program light and 12:00 are flashing, no buttons work
Press program set once, then switch to clock mode to set time.
Sep 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Braun Tassimo Espresso Machine/Coffee Maker Logo
4,425 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
ellipse0904
Level 1 Expert
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
