Some keys like esc,backspace and shift keys are not working in my samsung n148 plus metbook pl help to get a solution///////
SOURCE: hye mr expert...Here i have
The problem with your Netbook seems to be that you have turned "NUMBER LOCK" or "NUM LOCK" on. This causes some of the letter keys, e.g U,I,O,J,K,L,M to be printed as numbers 0,1,2,3,4,5,6.
To turn this off, hold down the "FN" key (near the bottom left of the keypad) and then press "F11" and then release both keys.
Please try this and post back if you need further assistance.
Regards,
BElectric
SOURCE: My Samsung NC10 netbook beeps repeatedly on
Maybe there is some viruses around or just some drivers are not working. Try system restore, if it doesn't help then do C: format.
SOURCE: hi i am nitesh i
Please disable the numlock and check the keyboard.
If still probem with the existing keyboard, you can use the external mini keyboard.
SOURCE: My samsung laptop R420, SHIFT
hello
you can use on-screen keyboard
if the problem is to with this on-screen keyboard
then you will know that the problem is not from your pc keyboard
Enter here to see how to get on-screen keyboard
SOURCE: hi, i ve samsung NC10 and the back space key and
BS, its some ******** bug samsung is **** they dont help many people have keyboard problems they should release a fix software also my spanish nf210 does not even have a working fn+f11 i had to run a software to turn numlock off how ******** and i still have the problem too that shift dont work and backspace dont work
