Question about Panasonic PT-52LCX65 44" HDTV
We have a Panasonic 52LCX65 TV that has a green spot in the upper right quadrant that shows when light colors are in that area of the screen but not when dark colors are. Happens with TV and DVD. Any idea what the problem is and how much it might cost to get it fixed? What causes it? Would it help to have it plugged into a surge protector?
  • 1 more comment
  • ynot4tech Jan 02, 2009
    I have the same problem. A baseball size spot slightly off center.
  • Anonymous Feb 08, 2009
    same problem
  • fackmann79 Feb 14, 2009
    I ALSO HAVE THE SAME TV. I HAVE FOUR OR FIVE GREEN SPOTS THAT ONLY SHOW UP AT TIMES WHEN THE RIGHT COLOR SHOWS UP SO DO THEY. I ALSO HAVE A BLUE DOT ON THE UPPER CENTER OF THE TV. I CHANGED THE LAMP AND I SEEMS AS IF IT GOT WORSE. I JUST NEED SOMEONE TO TELL ME WHAT I NEED TO DO.
  • 3 Answers
Just get the TV re-calibrated will solve the problem is 6 minutes but you need to take it to the shop.
Posted on Feb 13, 2009
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
What is phosporing screen
The colored spots may be a light engine issue that Panasonic will pay for repair costs even though tv is few years old. Contact Panasonic. . No you can't reset the lamp timer without a remote.
Oct 11, 2009 | Panasonic PT-52LCX65 44" HDTV
Right side corner green spot.
you may have some type of algae in one of your guns. you will have to open it up to see
Jun 28, 2009 | Panasonic PT-52LCX65 44" HDTV
Panasonic 52LCX65\PT Green Spot
COLOR CONVERSION IN THE MENU ,,TRY THAT,,IF NOT A NEW CABLE,,CONVERSION REALIGNS THE COLOR
Apr 17, 2009 | Panasonic PT-52LCX65 44" HDTV
Light green and pink spots on my hd tv!!!
Hi--Bought my panasonic pt-52lcx65 on sale for $2200 in 8/05. Replaced the lamp for about $300 in 1/08, just prior to Superbowl. Admittedly, this was to be expected after family members watched lots of tv over 30 months. However, two months later the blue spot emerged in 3/08, and red spot emerged 5/08. Set looks decorated by a Andy Warhol or Van Gogh wannabe. I'm looking for a fix it solution. Dr. Bob Heiliger, Lebanon, OH.
Jun 08, 2008 | Panasonic PT-52LCX65 44" HDTV
Yellow spots are appearing in the upper right quadrant of the screen. After the set has been on for a couple of hours a second spot appears in nearly the dead center of the screen. This issue coincides...
Try the new lamp as indicated by the blink codes. That may resolve the problem. If not, the problem is in the "light engine" portion of the set which should be covered under warranty.
Keep us posted.
Dan
May 29, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT 44LCX65 model
I also have this problem. TV is 2 years old. Service tech says the repair will cost about $600 per spot. I have 4 spots
Oct 30, 2007 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-52LCX65 44" HDTV Logo
226 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
