Question about Chicago Forge AF5HV 30 - Gal. 5.0 - HP Vertical Air Compressor
My motor boggs down before pressure reaches 15 lbs on my verticle vt631402aj compressor. what is this problem?
  • 65 Answers
Your non return valve is faulty the seal or the whole valve will need replacing
hope this helps ian
Posted on Dec 31, 2008
    Scholar:
  • 140 Answers
Check the oil first and the make sure the discharge tube is clear.
Posted on Dec 30, 2008
When max pressure reached engine dies instead of idle down
Has Pressure Switch Issues - About Air Compressors
www.about-air-compressors.com/has-pressure-switch-issues.html
Many times folks think that they have a pressure switch problem since air leaks out the ... The pressure switch does not kick off when the compressor has reached itsmaximum pressure. ... compressor sits humming and trying to turn the motor insteadof cutting out. It is a ... I have an old, about 20 year old, Ingersoll-rand T21.Missing: idle
[PDF]21 Front St. - Celtic Distributors Ltd
www.celticdistributors.com/content/Celtic/.../BasicCompressorTraining.p...
The air compressor motor and/or engine will get hot while in operation. .... enters thru the intake ?lter and the intake valve on the down stroke of the piston. .... My gas unit builds pressure but instead of idling the engine dies? 0 Check ... most single stage compressors only reach maximum pressure of 125 to 135 PSI. A slight.
[PDF]ALTRONIC GAS ENGINE GOVERNOR OPERATING ...
www.altronicinc.com/pdf/engine-controls/govinstall.pdf
Dec 16, 2015 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
I've got a Porter Cable pancake air compressor with, what I think is, a bad pressure switch. Plugged in, switch to auto, and nothing happens. Unit is bleed and gauge is at 0. I can get a new switch for...
You can test the other components of the compressor by temporarily by-passing the pressure switch. Connect line in to motor wires and plug in unit, unplug when pressure reaches 125 to 130 lbs. There is a safety relief just in case so do not worry. It the pressure does not reach target pressure there may be a leak or worn cylinder. If target pressure is reached in a short time replace pressure switch. Very easy repair. Good Luck.
Aug 07, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Makita MAC2200 runs fine (with new Manifold Switch and repaired power cord) but there is an air leak under the new manifold switch that seems to be a feature of the switch. When set to automatic, the...
I have worked on many makita compressors and have run-across this problem on a few of them. Your compressor has a check valve that is supposed to hold tank pressure after the switch reaches set pressure. There is an unloader valve built into the pressure switch that releases the pressure in the discharge hose after the unit shuts off. The unloader allows the compressor to restart with-out any pressure in the discharge line. If the brass check valve is leaking pressure back into the system, air will leak out of the unloader valve. Follow the discharge line to the tank and you will see the brass check valve. To test valve for fault, run the compressor till it builds around 80 psi and unplug the unit from the wall outlet. Remove the 1/4" hose connector from the check valve and check for air leaking out of the valve. If it is leaking you can order form www.toolpartsdirect.com. or call the makita 1-800 number. The price is about the same. Good Luck on your repair.
Mar 18, 2009 | Makita Air Tools & Compressors
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
My verticle vt631402aj compressor motor boggs down before pressure can reach 15 lbs.
hi your problem sounds tp be associated with your nonreturn valve this is not sealing ,allowing pressure to flow back to your pump from your reciever/tank ,this is a"service part"and do require replacement periodically
hope this is of help ian
Dec 29, 2008 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
My husky pro vt631402aj verticle compressor won't stay running when compression rises
Hello,check to see if it cuts off at the same psi each time.If so,youneed to adjust the pressure switch to the tank to the max & adjust the pressure to the tool you want to run with the pressure out kob.Hope this helps
Clarke hunter 60 2.5 hp compressor , trip switch keeps tripping
if you are talking about the brass valve with a small pin in the middle.it leaks untill the pressure get to 15-25 lbs then the pin pops out and stops leaking and the compressor pumps to pressure. this is normal that valve it a cold start valve that allows the compressor to start with out binding
Dec 09, 2008 | Air Tools & Compressors
Chicago Forge AF5HV 30 - Gal. 5.0 - HP Vertical Air Compressor Logo
292 people viewed this question
Top Chicago Forge Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Chicago Forge Air Tool and Compressor Expert? Answer questions, earn points and help others
