hi ive got an onkyo tx-sv373 and i got home from work today and turned it on and after about 1 second it switched off and the stand by light started flashing and now this is all that happends every time i turn it on, can anyone help
-   My Denon AVR-1600 amp simply shut off last night. Came back on for awhile then quit again. Power light still on. Any ideas? Should I fix or trash?-   wetztv
Mar 05, 2009
-   I forgot why i put the receiver in the closet: its "power off" mood swings. I've noticed that when the stand-by light is flashing, it's in one of it's moods. Once light stops flashing, e.g. three days later, the receiver will work... for awhile.
-   lalala848
Nov 20, 2008
-   Power on ... charging condensators ... after very short delay:enters std.by-mode with blinking LED.
Prior to the issue; Exposed to some heavy use in a 5.1 speaker configuration, though working after this.
B-Speakers also connected though not engaged while incident occurred.
Schematic for this with measurepoints and reference voltages -anyone?-   Norsch
Mar 21, 2008
-   I have the same exact problem. Has anyone had theirs repaired, I was wondering how much it cost to fix? Thanks, Ron-   Eastcoastron
Feb 27, 2008
-   Our receiver keeps blowing a fuse and stays in Standby! Does anyone have any suggestions as to the problem.?-   Candyk
There is a problem with one or both of the audio amp circuits. The amp is going into a protect mode as to protect and save your speakers. Sorry but there is no simple fix. this will need to go to the shop to be diagnoised. Good Luck
got a philips set top box at around 3am every morning it upgrades itself how do i stop this from...
(More)
GOT A PHILIPS SET TOP BOX AT AROUND 3AM EVERY MORNING IT UPGRADES ITSELF HOW DO I STOP THIS FROM HAPPENING. ALSO AFTER RETUNING I GET 114 CHANNELS HOWEVER EVERY MORNING I LOSE 15 CHANNELS HOW CAN I STOP THIS HAPPENING AND SAVE ALL 114 CHANNELS. HOPE YOU CAN HELP MANY THANKS STEPHEN
i am using a avr 1910 with a samsung bd-p1600 blue ray player via hdmi connection, when the player...
(More)
i am using a avr 1910 with a samsung bd-p1600 blue ray player via hdmi connection, when the player is set to bitstream DTS-HD the volume is very low, i have to turn the volume over 80% to hear sound, when the player is set to pcm there is no problem. please help thanks
Is there a wsay that I can convert my Bose wave radio/cd player from 220v to 110v, without an...
(More)
Is there a wsay that I can convert my Bose wave radio/cd player from 220v to 110v, without an external transformer ,having moved from the UK to Canada?
Our Onkyo keeps blowing fuses. It went out several years ago and we put it away on a shelf. Recently...
(More)
Our Onkyo keeps blowing fuses. It went out several years ago and we put it away on a shelf. Recently pulled it downt o try to fix it. Replaced a blown fuse and turned it back on and it immediately blew the fuse again. Any help available that you know of?
Comment by Guest, posted on Nov 09, 2007
Onkyo TX-SR804 7.1 Channels Receiver does not stay on. It automatically turns off within a second after I turn it on. Happens everytime now......TJ
