Question about E-Machines eMachines Desktop PC
Beeps when starting up
My emachine t5246 is beeping when I try to boot it up and the fan turns on but that is all it does. Any suggestions?
  • heatherskans Dec 29, 2008
    it is long beeps and countinues until I push and hold the power button for it to shut off.
  • heatherskans Dec 30, 2008
    I just wnated to say thanks! I did not have to replace the ram just had to take it out and put it back in.
    Master:
  • 413 Answers
I need to know how many time it beeps. THat actually tells you what is wrong. This site tells you what to listen for. Let me know if you need any interpretation
Posted on Dec 29, 2008
  • Dan rogers
    Dan rogers Dec 29, 2008
    It sounds like it might be a problem with your ram. It is relatively easy to replace if you know the inside of a computer or know someone who does.
Emachines 5805
Sounds like a bad motherboard. It's getting power and turning on the fans and everything, except booting it up. Yeah, sure sounds like a bad MB. How old is the pc? You have to be careful with Emachines. They are built cheap and break often.
Jan 02, 2014 | Dell Computers & Internet
Emachines el1352g-01w beeps while booting up
be sure nothing on you keyboard or pressing any key
Dec 04, 2012 | eMachines EL1352G-01w (884483537679) PC...
My emachine turns on, the fan blows but it never boots up. The fan just keeps blowing. Any suggestions?
Well there is couple of culprit that cause this issue which ranges from a bad vga, motherboard, ram or even the cpu itself, First of all, check to see if you hear any beeps after turning the computer on. If you hear random beeps or constant beeps then it could be something wrong with your memories. The only way to test things out is if you have other hardware parts to test it otherise it is hard to pin point what is actually wrong. A simple thing that may help is by resetting the cmos, in this case you can take the side panel which would be on your left off by unscrewing the screws in the back of the case panel. There should be a nickel size battery on your mainboard. If you don't know how to short the pins, go ahead and just take out that battery for about 15sec or so and replaced back on. Then try to start your computer agian. If it works then good, if it doesn't then it could be other hardware component that become faulty. Like I said the only other way to know what is actually wrong is to have spare component parts to test it with.... other then that, you may need to take this to a computer repair place since the have the parts to diagnose it with.
Jan 15, 2011 | E-Machines eMachines Desktop PC
My emachine t5246 just beeps when i turn on why?
This could be a memory dump issue or a parity cheksum issue
what you need to do is open up the tower and take the memory strips out and reseat the same and reboot the system
Dec 26, 2010 | E-Machines eMachines Desktop PC
Emachine starts boot process but stalls, no beeps
most likeley if you see something on the screen but it wont boot it is a mem problem, does it load bios, if so it is prob not memory
Nov 17, 2009 | E-Machines eMachines Desktop PC
Turn computer on. Three beeps, fan on, won't go through set up.
I have left you a webpage to get your infomation on.
Without knowing what BIOS you have or model number of motherboard, I can't go any further.
http://www.techspot.com/vb/topic95391.html
Oct 05, 2009 | E-Machines eMachines Desktop PC
On starting my desktop(emachines e4216)the machine emits 3 beeps.
3 beeps - check the manual for the motherboard that you have or your computer manual and it should tell you what the 3 beeps means.
If you need to find out what motherboard you have you should either be able to use wcpuid or SIW ( google them ) and you should get the correct utilities ( if not post back and I can post some links )
I would also suggest ( as long as its not under warranty still ) to take the side off of the computer and give the inside a clean out using compressed air.
Has it got anything new hard ware wise that was installed as this might be sapping too much power and stopping it from booting ?
Apr 10, 2009 | Computers & Internet
Disabled video driver. Now unable to reboot emachines T5246
reset your bios settings put cmos cell for 15 minutes. also u can reset bios with jumper settings.
then remove meory card then check beep.
then connect allconnection then try.u can do it man.
Jan 05, 2009 | E-Machines eMachines Desktop PC
Emachine Will not boot
different beeping patterns are codes which indicate what part of the hardware has failed (ram, video card, cpu, ect). the fan failure would not cause beeps, and would not cause the cpu to fail unless already in windows. if you could find out the manufacturer of your motherboard you could check with them about what the paticular pattern of beeps which you are getting mean.
May 17, 2008 | E-Machines eMachines Desktop PC
Emachines wont boot
Bad capacitor(s) on the motherboard can cause this problem, corrupted BIOS maybe... try flashing BIOS.
Probably the CPU if your not getting any error code beeps on startup.. NO Processor for the BIOS instructions thus no Beeps !
Nov 27, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
405 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
