Question about Kenmore Oasis HE 27082 Top Load Washer
The start button does not function properly when pressed
We have to continue to press on it. Sometimes it works right away and sometimes we think we may be headed to the laundramate.
  • kennthompson Dec 30, 2008
    Press start and CLEAN WASHER WITH BLEACH light comes on.  Washer has been cleaned numerous times and problem continues.  Sometimes it works; sometimes it doesn't.  Seems to have a mind of its own.
    New Friend:
  • 88 Answers
It sounds like your touch pad is going bad. the cpu behind it is probably gonna go soon. unfortunately.
Posted on Jan 08, 2009
Service mode enter
Press and hold function , copy and 3 in that order. Should read f1 self test . If not press reset or stop and retry.( sometimes a bit tough to get it right the first time) to get out of service mode, press function and c ( clear next to the start button) together.
Oct 11, 2013 | Panasonic DP-C264 Copier
When I sync my Iphone with my mac I lose the internet connection on the mac. Sometimes for 3 days. I shut everything down and it sometimes comes back right away.
i think your i phone driver or software are not installed properly. install it carefully and check the connectivity again.
May 06, 2012 | Apple Mac OS X
I lost my code guid to this remote.. How can i find the right code i need?
I actually need the device you want to program with your remote control but then you can still try these steps:
1.Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired device button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the ON•OFF button repeatedly (up to 300 times) until the device to be controlled turns off. The red indicator blinks off with each button press.
Most users will store VCR codes under the VCR button, Cable codes under CABLE, etc. If (for example) you want to store a VCR code under CABLE, first follow the procedure for Direct Code Entry (previous page) and press CABLE in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Note: Code Search starts from the currently stored four digit number under that mode. Sometimes the first code that “works” with your device may only allow limited functionality (e.g. the MENU button might not work). There may be a code that performs more functions. Continue the code search process until the best code is found.
Aug 27, 2010 | GE JASRM24912 Remote Control
My front load washer goes into pause two min after machine is started i have to press start for cycle to continue and sometimes it does it a second time press start again it will then finish cycle
you should check button start / pause the washing machine, if it is damaged you must replace it with a new one, the damage caused by the push button which is not connected properly.
Aug 11, 2010 | Frigidaire ATF6000ES Front Load Washer
I have lost the ge universal remote guide for the codes its a ge sku 24914 universal remote i need the codes to program the remote
These are the steps on how to program your GE Universal Remote Control without the list of codes.
1. Manually turn on the device to be
controlled.
3. Press and quickly release the desired device button. The red indicator blinks off once.
5. Press and release ENTER to install the code.
Jun 13, 2010 | Universal Remote Control GE174Universal...
I need to get the programming codes for a ge universal remote control, where can I go?
It really depends the model of your GE remote control. But then I can advise you to do these steps so you can program your remote control without the list codes.
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
Jun 12, 2010 | GE Televison & Video
I can't use any USB, it needs a registration on my laptop.. but i don't know how.. help pls!
If you can't use any usb device, the usb function is disabled.
  • To enable the usb function you have to access the Bios setup of your Desktop.
  • By pressing Delete button, F2/F11 button or Esc button in order to open the Bios Settings.
  • During power on the button menu will show up (press the key right away before the Windows starts)
  • In Bios setup there are several menu. Check each of them until you found the settings for Usb Functions
  • If the Usb Functions is disable change it to enable
  • Then go to the Save Menu and Save to apply the settings you created. (Sometimes F10 button is use to save the settings)
  • Restart the computer
To check if the Usb Function is working in windows mode open:
Start Menu > Control Panel > System > Hardware tab > click Device Manager.
Under Device Manager
click the ( + ) sign in Universal Seria Bus Controller
You'll see all the Usb devices detected in your computer
Jan 14, 2010 | Computers & Internet
2004 Jeep Liberty CD Problem
Sometimes if you shut off the vehicle, then continually press the eject button, while you start it, and continue to press the button, until the radio is on for a minute, it'll work. Other than that, Sorry. Best wishes to you.
Jan 21, 2009 | 2004 Jeep Liberty
Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 19, 2008 | Microwave Ovens
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
