Question about Pioneer AVH-P6500DVD Car DVD Player
Blank face when unit is upright.
All is normal until screen starts to tilt up. i believe it might be stretched wires maybe there is a nick in the wire band. where can i get it fixed locally without spending as much as getting a new unit. i live in Pa.
  • countryboy_0 Jan 23, 2009
    When the screen is coming out if u look under the screen it is lit up but not as bright and when it lifts up it is black
  • 3 Answers
What you need is called a flex ribbon for the unit. Its a cable of flat wires that will be attached from the screen to the head unit.
you can find them on Ebay for like $60 or $70 but that will fix the problem with it. I had that same problem with my AVH-6500dvd and bought the flex ribbon and then I installed it myself but it was not a simple task to do. I would recomend taking it somewhere to get fixed.
Posted on Feb 21, 2009
  • Dvasquez_23 Mar 25, 2009
    There is a bid you can buy on Ebay for repairs they are Repair tech City they can fix your problem for about $130 and work well.
Screen is blank... still have sound and controls. too back to store and the screen worked on the store display model.
Your problem is the wires in the unit that hooks to the connection plate to the face plate there is a wire that burned up and not making the connection, youll see the wires when you put faceplate on and tilt your screen its like a orangish yellow wires that is hooked into the slot that your faceplate connects to a wire has burnt up probably caused by the brake wire that wasnt hooked up or from pulling off the faceplate to many times HAD TWO OF THESE DO THE SAME THING neither one I had ,had brake wire hooked up and probably caused it to short out.
Mar 14, 2011 | Pyle PLD51MUBT Car DVD Player
My oreck halo starts and stops when vacuuming. you get two or three motions and it stops. my hand tingles when i vacuum. can you tell me what is wrong. it was bought in March of 2009
sound like you have a loose wire inside the unit, " DO NO USE TILL ITS FIXED ". Carefully start taking apart in the locations where the wire runs through. Pay attention to all the wiring, any little nick could be the problem. Somewhere in there a wire is touching the inside of the unit. You might want to get intouch with Oreck, that is a manufacturing defect, and not worth a law suit if you get electricuted from it. Thats what the tingleing is, your getting juiced by it.
Mar 06, 2011 | Oreck HALO100 Bagged Upright Vacuum
I have a Pioneer DEQ-7600 and every so often I have to tap my dash board in order for the display lights to come on the front of the unit, like it goes in and out every so often, thanks Nick
Nick i believe that you have a simple ground loop problem. To fix that you'll need to run a ground wire from your EQ to the body of the car. (the shorter the wire,the better the ground)
Find the ground wire (black wire) coming out of your EQ. Splice a wire into that wire,and then connect that wire to the black wire coming out of your Head Unit,and that should solve your problem.
Feb 11, 2011 | Pioneer DEQ-7600 15-Band Car Equalizer
I dropped my laptop, Vaio VGN-NR185E, and the screen is turning blue with the white colors, so if there's a blank page it's blue instead of white, I believe it's the inverter or maybe a loose wire, What do...
If the unit was dropped, it could be that a wire /cable came loose,but it most likely is the LCD screen. Was the unit dropped on one edge of the unit or did it land flat?
on edge: probably the LCD screen
flat: loose cable or inverter
Best guess....without seeing unit.
Nov 15, 2010 | Sony VGN-NR185E/S VAIO NR Series
AC Fan outside running slow
The brown wire goes to the capacitor. It probably shorted out with the nicked wire. Replace the capacitor.
Jun 29, 2009 | Goodman CKL36AR36 Air Conditioner
Kenwood 8pin harness
looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Sep 27, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Fan does not work.
I'm working on one right now and I believe it's the capacitor. It's hard to find this capacitor. So far I've tryed 3 HVAC suppliers and none have this rare capacitor. First UNPLUG THE UNIT. Take the phillips screws out of each side in the front. Then take the 3 screws out of the face of the control. There are 3 white common wires and a dark brown compressor wire and a light brown fan wire. Take the 1/4 inch screw out and unplug the wires and find another one.
Aug 05, 2008 | Whirlpool ACQ158XP Wall/Window Air...
Laptop HP Compaq nx9420 Screen goes Blank
From the Symptom you described, it seems like the thin video cable's connector is loose and is barely connected to the video adapter on the motherboard. You won't be able to tell until you remove the Keyboard and/or the Palmrest to check it. Also, there is a slim possibility that the Laptop has knocked something loose and is going into sleep mode. Normally, a Laptop user can configure it to go into Sleep mode or 'Hibernate'. These settings can be found in the Control Panel under 'Power Settings'. http://www.Computer-Repair-Today.com
Jan 06, 2008 | HP Compaq nx9420 Notebook
LCD screen turns off when back in body
We had a similar problem. If you remove the cover to the place where the LCD hinges, you will find two little wires broken off. These attach to a black touch sensor resting in the lcd screen. It comes out easily and without issue. WIth the two wires torn, the camera does not recognize that the LCD display has been turned around. It turns the screen off because it believes you have the LCD screen pointed inward towards the body of the camera. A small extension for the wires and a soldering iron solved that set of problems.
Sep 28, 2007 | Canon PowerShot G2 Digital Camera
Pioneer AVH-P6500DVD Car DVD Player Logo
193 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
