Question about MSI 865PE Neo2-V Motherboard
Pin assignments i am installing a 865pe neo2-v motherbord ans need to know the power ,reset , hhdd led... locations
  • 59 Answers
Follow the manuals instructions, the cables should match or be similar to the manual. There's no problem with guessing in these situations if the cables and pins don't match go nuts you won't damage a thing.
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=591
Posted on Dec 29, 2008
MSI 865PE Neo2-V Motherboard does not boot to BIOS. It just powers up and the drive lights are on continuously. Is there a replacement MB that uses essentially the same BIOS and won't require re-formating...
This one is pretty much identical
http://cgi.ebay.com/MSI-865PE-Neo2-P-Motherboard-P4-socket-478-EMS-/180572214688?pt=Motherboards&hash=item2a0af155a0
This one is similar but you will need to reinstall a new audio driver
http://cgi.ebay.com/MSI-865PE-NEO-2-Motherboard-Processor-/200552149636?pt=Motherboards&hash=item2eb1d6f284
Dec 09, 2010 | MSI 865PE Neo2-V Motherboard
What is the max ram that I can install in the 865pe neo2-p board
The MSI 865pe motherboard can use up to a maximum of 4GB of PC1600/2100/2700/3200 non-ECC DDR RAM
Apr 04, 2010 | MSI 865PE Neo2-V Motherboard
Can prescott 800 mother support p4 2.4ghz/1m/533 processor
The MSI 865PE Neo2-PLS
Supports Intel® P4 Northwood/Prescott (Socket 478) processors.
FSB 400 (for Northwood only), 533, 800MHz.
Supports up to 3.2GHz or higher speed.
See page 1-2 in your manual. Also see page 2-3.
MSI supported CPU list; http://www.msi.com/index.php?func=prodcpusupport&maincat_no=1&prod_no=569#menu
Main link for 865PE Neo2 platform; http://www.msi.com/index.php?func=searchresult&keywords=865PE+Neo2
Cheers'
Mike
Jan 20, 2010 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Starting PC: No Beep, No LED on motherboard, all fans seem to have power. No videosignal at all. Videocard and cable OK.
This MAY be the power supply. Fans often run from different voltage than most of the processor.
The power on reset may not be releasing as one of MANY possible problems. Power supplies are less expensive to try tahn motherboards.
Jan 04, 2010 | MSI 865PE Neo2-V Motherboard
How to connect my led lights[that is the red nd green light ] with my 865 chipset''......where r those pins on the motherboard ??
in *********** board where the reset & power botton is connected same place you can find HDD LED for Harddisk and Power LED for power, please be carefull with the sign designation about (+) and (-) it is indicated in the board and pin.
Jun 12, 2009 | EliteGroup ECS 865PE-A7 Intel 865PE...
Is MSI 865PE Neo2-V motherboard support graphic work?
Most of the applications that you have specified above use high amount of the memory. If you are using vista this makes it even worse. Get another 512MB RAM and install it in the next DIMM slot and it will be alright. 512MB Ram should cost you around 500-700Rs.
Nov 13, 2008 | MSI 865PE Neo2-V Motherboard
MSI 865PE Neo2-V Motherboard Logo
112 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
