Question about HP LaserJet 3030 All-In-One Printer
Printer HP laserjet 3030
My printer makesa churning noise while printing. It also leaves a thick line on the right of the paper
  • heckelectric Jan 27, 2009
    My printer recently was a little noisy like something was stuck in there when i was printing now there is smear streak just on the right edge of the paper
  • 43 Answers
If toner cartridge doesn't fix problem you may need a fuser as fuser film either torn or moved too much to the opposite side causing the black band on page.
Posted on Jan 14, 2009
  • 81 Answers
It sounds like a faulty toner cartridge.Try changing the cartridges and see if this solves the problem
Posted on Jan 03, 2009
Light and dark lines on hp laserjet 3030
Replace transfer roller & check..As well as check teflon sleeve surface for any toner particles deposited on it..
Sep 03, 2012 | HP LaserJet 3030 All-In-One Printer
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
HP LaserJet 3030 Paper is crushed from top right edge when printing/copying. How can/do I fix this? I have used a heaver weight paper and it does not get crsuhed, however the print is usually smudged right...
Try reseating your Ink Cartriges first then try printing to see if the error still appears, if it does try reinstalling your printer drivers... make sure you check your printer cables if they are conencted properly to your computer after reseating the cartriges.
May 21, 2010 | HP LaserJet 3030 All-In-One Printer
Hp 3600n prints 3 faint lines on letter head only and not on other paper. What is causing this?
It could be a couple of problems:
1. Your toner needs to be changed
2. You need to clean your printer
3. You paper weight is too thick and the toner is reacting to it by leaving streaks on your paper.
See if those help
Jan 14, 2010 | HP LaserJet 3600n Printer
Hp 3030 laserjet paper creasing when printing
if the print is also smudged the fuser needs replacing
Jan 12, 2010 | HP LaserJet 3030 All-In-One Printer
Hp LaserJet 3030
Make sure that the paper size is set to letter, not legal. Check this on the printer and the computer printer software.
Aug 21, 2009 | HP LaserJet 3030 All-In-One Printer
PRINTER MAKSE A CHURNING NOISE
Do a half self test. To do this print anything and open the cartridge door when paper feeds into the printer but before it reaches the fuser. This will tell you if problem is with toner or fuser. In order to check the fuser remove toner, in back of printer you'll see a cover held in by 2 screws. remove screws and gently pry cover enough that you can shine flashlight and see the fuser film. If torn replace fuser.
Dec 29, 2008 | HP LaserJet 3030 All-In-One Printer
SMEARED PRINTING ON RIGHT-SIDE MARGIN
Ist I take it you have replace the toner/drum. If not do so. If you have then check the paper path to make sure there is nothing in the way, like a torn piece of paper or a label stuck in there? If you are 100% positive the paper path is clear there maybe something stuck in the fusing unit.
Feb 11, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3030 All-In-One Printer Logo
167 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
