Question about Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1525 touchpad not working properly
I have a dell inspiron 1525 which i purchased 2 months back. generally i dont use the touchpad so i keep it disabled. today when i enabled it ,surprisingly i was not able to scroll using the touchpad. i checked all my touchpad settings and also tried checking online for updating my tochpad driver settings. but then i cudnt find anything.so please help me!
  • 1 more comment
  • nitro5440 Feb 09, 2009
    same problem, scroll bar thingy on the side of the touchpad doesn't scroll anymore, hasn't worked for several months now...and the solution the dude posted didn't work
  • Anonymous Feb 24, 2009
    The two black bars on my touchpad used for scrolling are not working, i dont know weather its a hardware problem or a setting , or perhaps a not up to date driver , anybody know how to solve this ??
  • riyadh_arg Apr 27, 2009
    same proplem in synaptics touchpad driver dell 1525
  • 27 Answers
You can try the following steps.
1. Turn laptop off.
2. Remove all external devices and disconnect AC adapter power cable from the system.
3. Remove the battery from the system.
4.Hold down the power button continuously for at least 5 seconds. Do not release the power button during this process.
5.Insert the battery back to the system.
6.Power the laptop back on.
Try using touchpad again.
Posted on Dec 29, 2008
Dell insprion 1525. 1st cursor pad not working. When AC power plugged in, it worked but the right and left click buttons don't work now. Any solutions?
Posted on May 17, 2009
  • 20 Answers
I found after updating the Touchpad software from the Dell update site my touchpad no longer functioned correctly.
The problem was the drivers on the website were older than the drivers on the computer when I got it from Dell.
I had to do a complete restore to factory status before I fixed the problem. Just checked the dell update site and it appears to be the latest driver available there, version 7.1.1500.2 is what I am currently running with full factory function.
Posted on Mar 27, 2009
Inspiron1525 touchpad not working
Posted on Sep 29, 2009
Dell touch pad not working
The touchpad on a Dell laptop is usually located under the keyboard. Moving the finger on the pad moves the pointer on the screen. The buttons near the pad act as a right and left click. Windows includes a method to troubleshoot the touchpad. In addition, if the touchpad is still giving you issues, Dell recommends draining the "flea" power the standby power from the computer to restart it. Both methods are simple and only take a few minutes.
Open the control panel from the Start menu. Click on "Mouse." This will open a window with several tabs. On the first tab, click the touchpad to open a new window to change the settings for your touchpad. You can customize the settings to how you want your touchpad to work. If this does not solve your issue, proceed to the next step. Click the Hardware tab on the screen that pops up. Select the Dell Touchpad and click "Troubleshoot." A new window will open with the Windows Help and Support Center to bring you through methods for troubleshooting the touchpad. Follow the methods described until your touchpad is working properly. Drain flea power Shut down the laptop and disconnect all external devices, such as a thumb drive, headphones and the AC adapter power cable from the system. Take the battery out of the laptop. Hold down the power button for at least 5 seconds without releasing it. Return the battery back to the laptop. Power the system on. If your touchpad still is not working properly, call Dell for customer support.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=59EB83ED2E4B1243E040AE0AB7E1468E&doclang=en b> Dell Inspiron 1525 Touchpad That Is Not Working
Turn your Inspiron 1525 off and remove any power cables that are connected to the device. Close the computer, turn it over and slide the battery lock button down to release the rectangular battery from its compartment on the underside of the computer. Turn your laptop right-side up and open the computer so the monitor is facing you. Insert the tip of your flat-head screwdriver in the seam between the plastic keyboard guard and the side of the computer. The keyboard guard is located just above the keyboard. Pry up on the guard until it pops out of place. Be sure to do this gently, as you do not want to damage the guard. Remove the guard from the computer and set it aside. The two keyboard screws will now be visible underneath where the guard used to sit. Use your Phillips screwdriver to remove the two keyboard screws and use the tips of your fingers to lift the keyboard up from the top. Place the keyboard facedown over the touchpad and locate the thick connector ribbon that runs from the motherboard inside the computer to the back of the keyboard. Use your fingers to gently unplug the ribbon from the back of the keyboard and set it aside. Insert the tip of your screwdriver in the seam at the bottom of where the keyboard used to rest and gently pry it up. This will release the top plastic frame from the Inspiron, revealing all of the broken touchpad. Use your fingers to disconnect the thick ribbon from the side of the damaged touchpad and slide the touchpad out of the Inspiron. Slide the new Touchpad (available from your Dell retailer or online) in its place, fit the top frame in place and reassemble the computer in the reverse order you took it apart in.
http://www.insidemylaptop.com/replace-damaged-keyboard-dell-inspiron-1525-laptop/ Replace keyboard in dell inspiron
Feb 01, 2013 | Dell Inspiron 15 (N5050)
My inspiron 1525 touchpad is broken, if i dont use a mouse the cursor will not going to move, stock. please help me how to solve this problem. thanks
If this is physically borken then you will have to get it replaced or a temporary solution is that you can use a usb mouse.
and if it is an issue with just the cursor and the touchpad is intact then you will have to reinstall the drivers and it will work absolutely fine.
you can do it from the dell drivers cd or you can go to the dell support website.
www.support.dell.com click on drivers and downloads and download and install the Dell touchpad/pointing stick drivers.issue will be resolved.
Nov 02, 2010 | Dell Inspiron 1525 Notebook
Scroller of touchpad of dell inspiron1525 not working
it will need fixing by dell contact them it wont cost as it is a warranty repair
Aug 06, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Inspiron 1525 noisy right button on touchpad
Normally all the mouse buttons make a click sound when you press a button, some makes, the click is louder that other makes.
Purchase a mouse that is more to your tastes.
Apr 29, 2009 | Dell Inspiron 1525 Laptop
Inspiron 1525 Touchpad has a mind of its own
I would try using what they call a cool mat. It sits under your computer and plugs into your computer per USB. It helps keep the computer cool. They cost like 25 dollars.
Mar 26, 2009 | Dell Inspiron 1525 Notebook
Laptop touch pad mouse does'nt work while charging
my toch pad dont work when my laptop is charging i have inspiron 1525
Feb 26, 2009 | Dell F3534 Touchpad
Scroll doesn't work
Update the touchpad driver. Click this and follow the wizard.
Dec 28, 2008 | Dell F3534 Touchpad
Dell Inspiron 1525 Laptop Jet Black  Logo
4,860 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
