Question about Kenmore 24032\24036 Top Load Washer
Kenmore model 22432100 - it won't drain or spin
Any idea what's causing this machine to not release the water once the rinse cycle is complete? It makes a buzzing sound only without releasing the water and when I try to manually set-it up to spin, it won't spin or do anything? If I reset it manually to washing or rinsing, it will wash and rinse or I can add water. But then once the washing or rinsing is complete when the machine is supposed to get rid of the water and move into spinning, it makes a faint buzzing noise and it just stops.
  • 1 more comment
  • pjp5908 Jan 18, 2009
    same problem. whats the fix?
  • meberger61 Jan 18, 2009
    washer full of clothes; stops at spin and won't go further; wash cycle works just fine. we have checked all fuses, unplugged and plugged back in. washer is full of water as well
  • sunny s123 Apr 28, 2009
    The locking mechanism on the lid won't hold so the spin cycle can start. I can read in and hold the button on the machine but it's rather time consuming and painful to my hand.
  • 179 Answers
Sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Posted on Dec 29, 2008
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Kenmore elite washer won't drain
What is the model number of your washer? This condition is caused by a bad lid switch.
Aug 13, 2012 | Kenmore Washing Machines
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
I have a top loading Kenmore washer model # 22432100. It won't drain the water and spin. I completes every cycle up until then and it just stops. When I restart it, it works until draining,...
this is a direct drive washer the reason your unit is depending on if your hearing the motor running or not would either be the motor which i do not think it is or the drive coupler which connects the motor to the transmission and lets the unit spin here is also a video on how to do the repair for the drive coupler if when you disassemble you find the drive coupler intact and not broken message me back then for further diagnosis Thanks again heres you video http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5457341501&kw=washing%20machine%20coupler
Rick
Jun 15, 2011 | Kenmore Washing Machines
Kenmore model 22432100 wont spinn or release the water
Hi.
Check if there is drain blockage. That will result in cycle not advancing to spin. To check drain system, check first the drain hose at the back and then access the hose connected to the drain pump. The drain pump is accessed from the bottom of the appliance. Disconnect power first.
If there is no drain problem, check pressure switch and lid switch.
Here a general article containing more detail about the no-spin problem: If you have no spin ...
Regards.
Ginko
Apr 18, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 24032\24036 Top Load Washer Logo
1,280 people viewed this question
Sal De
fordexpert
Robert Rankin
