Question about Dryers
Whirlpool LE5810XP Electric Dryer wont start
I put in second load of laundry in dryer today, set the timer and pushed the start button and nothing happened. I can hear the timer ticking. Also, when the timer is in the off position and the start button is pushed, it usually buzzes, but not doing that either
  • Maria Ferretti Dec 29, 2008
    The model is actually a LE7680xsw1. Sorry for the confusion
  • 248 Answers
SOURCE: Kenmore 27 inch wide electric dryer
Can you turn drum by hand? If so you probably need a motor.
Posted on Nov 19, 2007
  • 979 Answers
SOURCE: whirlpool dryer won't start
It sounds like you have lost a leg of power. Turn off both breakers, then back on. Then check the receptacle, the plug and then the wiring to the back of the dryer. This is likely where it is. There is a thermal fuse located under the top of the dryer. Easy to get to. Bypass it and if it works then, just replace it for about 15 dollars.
Posted on Feb 03, 2009
  • 3361 Answers
Ticking is from timer.
Check the door switch and the thermal fuse located on the exhaust vent.
Posted on Feb 21, 2009
App King
  • 55 Answers
SOURCE: Dryer drum will not turn.
If the buzz continues to go for awhile(2-3 minutes before you stop it you will need to replace the belt on your dryer.
If the buzz quits pretty quickly after you let go of the start button and you smell something hot or electrical, you will need to replace the motor.
Please let me know if you have any other questions.
Posted on Jul 22, 2009
  • 585 Answers
SOURCE: Whirlpool LEQ8000JQ - My timer ticks but the dryer
More specifically, the timer can be heard running, starts and stops when door is closed/opened, so not likely to be the timer. You have a problem at the motor. A wire off a terminal, the switch on the motor, or the motor itself.
Posted on Nov 29, 2009
I did a load of laundry and everything was fine. Later I put another load in the dryer and pushed the button and nothing happened. When you open the door the light comes on and then when I close the door...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Nov 04, 2010 | Whirlpool LEQ9858P Electric Dryer
It will not start up. When I put it on the timer setting it makes a buzzing noise but when I push the start button nothing happens
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Sep 10, 2010 | Whirlpool LER5636P Electric Dryer
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
I have an electric whirlpool with start switch not working
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer wont start
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
LER8858EQ2 electric dryer will not come on.
Thermal fuse on the blower housing is open. Take back off and the thermal fuse is near the blower outlet. It is white and about 2 inches long. Part number is 3392519
Dec 12, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryers Logo
160 people viewed this question
Top Dryers Experts
