Question about RCA HD52W59 HDTV Projection Television
Hooking a Wii to Dish Network reciever(not a hd tv)
I'm trying to hook up a wii and a dish network reciever to my tv. could someone please explain what do i have to do!!!
    Scholar:
  • 90 Answers
It sounds like you have a pretty new TV. This means that there should be multiple AV jacks in the back for setting up your many components. Plug in the receiver into #1, the Wii into #2, and any other equipment you may have (DVD, VCR etc.) in the same way. You should then use the original TV remote to switch between Video 1, 2, 3 and so one for each compnent you want to use. The button on the remote will be labeled video, tv/video, input select, or input, something like that.
Hope this helps!!
Posted on Jan 02, 2009
I need help with the HDMI cable/TV/DVR511 reciever? How do I hook up?
Hi my name is Mike Houston of DISH Network and I see you want to connect your HDMI cable to your 511 DVR receiver. To have capability for your HD TV you will need to have a VIP HD series receiver, I will be more than happy to assist you with this and you can contact me at Michael.houston@dishnetwork.com.
Sep 15, 2011 | DISH Network Televison & Video
What channel does my tv need to be on? and what button do i press on my dish network remote to get me to the wii screen
Usually it depends on how you connected to the TV/satellite box- for instance, I have mine set on channel AUX 1 since I have connected my Wii to the TV using the component cables (the red yellow and white cables) to the port AUX 1. If you've hooked it to the Dish box, then it would be whichever accessory you connected is the channel to select in the dish system, but on the channel that your dish is hooked up (it's situational!)
Jun 25, 2011 | Nintendo Wii Console
I have installed the WII, the problem is I don't get any game to come up. What does the TV have to be on inorder to get the game. We have DIsh network and the TV is a Phillips.
Try going to one of the "Inputs" on the TV. Make sure the system cables are plugged directly into the TV and not the Dish Network box.
Feb 27, 2011 | Nintendo Wii Console
Can i connect my wii console to my tv thru my dish network dvr
I hope that you have found the proper solution for this. The Wii console only has an "out" port, no "in" ports. This means that you can only connect the Wii to the tv, and nothing to the Wii, so you are not able to connect this between your receiver and tv.
Becki Barned
DISH Network Customer Service
Oct 22, 2010 | Nintendo Wii Console
Receiver taking a long time to transmit reciever
I assume that the HDMI works fine if you go directly from the dish receiver to the TV with either HDMI cable. And try it with a different source (DVD or x-box) in the same input port.
Take it to a Radio Shack there service centers can repair Onkyo in warranty. Most Onkyo receivers carry a two year warranty.
Nov 18, 2009 | Audio Players & Recorders
I have a 20 inch sanyo hd digital hooked up as a second tv on dish network receiver. I had to unhook it temp and when I hooked it back up, no picture. I tried channel scan and nothing. How can I get the tv...
bring the tv out to the main tv and hook it up to that connection to determine if it's the TV or the connection. Or try hooking up a VCR to the tv while the TV is set to CH 3. Do you get a blank picture or a snowy Picture?
Sep 20, 2009 | Sanyo Televison & Video
Hooking up a dish network to my tv
Well, I don 't have that T.V. but I can tell you that you may have to go to your menu and look for your channel setup and change it to another channel output. If that doesn't help then have it search for channels.
Jan 30, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I can't figure out the input select
Try leaving the Wii on and switching the TV off then on. I have an old TV and this is the only way I can activate the AUX
However sometimes even this will not work and you have to plug the Wii into a DVD player or Video player then plug that into the Aux to get it to work
Dec 26, 2008 | Nintendo Wii Console
Hooking VCR to DISH Network Reciever Box
In order to diagnose the problem I need your help.
Have you hooked the dish receiver directly into a tv or another device and had it working?
Have you tried a different cable at all?
Have you tried pressing the ant. button on the remote or tv/vcr button?
Please update me with as much info as possible and I will figure out where the problem is coming from. thanks
May 04, 2008 | Toshiba W627 VCR
Hooking up a tv
Hi first of all are you using scart leads to plug into each device here is how it should be set up ok
1. Scart lead from dish network into vcr
2. then other scart from vcr into tv
3. Now ti recieve the signal from the dish network you need to have the telly on the right av channel so that its picking up the signal from the vcr.
you can test this by changing the channel on the vcr controll or direct via buttons on vcr.
If the channels change then your on the right av channel.
Now when your on right channel on telly you need to now make sure dish network is on and on a channel or press the tv guide button just so you know what your looking for when the picture comes through.
You need to press av on the vcr controll this will then pick up the signal from the dish network via the scart lead as av is the channel for scart lead.
say if you was recording from dish net to vcr you would put the vcr on av to pick up the signal so press av on vcr controll this should then allow you to watch the dish network with no problems.
Let me know if you still cant and ill assist you further if it dont work tell me what you have done so i know how much you have done ok
Feb 10, 2008 | Toshiba TheaterWide 46HM94 46" Rear...
RCA HD52W59 HDTV Projection Television Logo
1,192 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
