Question about KitchenAid JAVASTUDIO KCM534 14-Cup Coffee Maker
My kitchenaide javastudio stopped working
After 10 seconds it simply beeps and displays an errror 2? the unplug, sit for 30 minutes and plug in again does not resolve the issue. any thoughts?
Err2 is a failed heating element. There is no fix or replacement parts sold. I was lucky I had a receipt, even out of the year warranty they(KitchenAid) are still replacing it.
Posted on Feb 03, 2009
Resetting computer on kdte204dss0 Kitchenaid
The most common reset for the dishwasher is:
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | KitchenAid Dishwashers
My Kitchenaid cooktop is not working, but is beeping. How can I turn it off?
Have u tried unplugging it for about 10 minutes then plugging it back in? Sometimes doing thus can reset it. It is only a quick fix and a qualified serviceman should called to completely fix the problem.
Nov 27, 2014 | KitchenAid KECC607BSS 30" Electric Cooktop...
My midland weather radio wr120 makes a loud beep about every 30 to 45 minutes. what is causing this?
I just caught mine in the act and the message was "BAD RECEPTION" - but it doesn't stay on the display very long, if you don't catch it right when it beeps, you'll miss it.
Sep 03, 2011 | Midland WR-100 Weather/RDS Radio
KitchenAid KEDT105V Electric Stove - f-5 beep Started beeping out of the blue, pushed cancel and it stops for 20 seconds then continuous beeping. If the oven is on the beeping will stop. Hope you can help,...
Hi, F5 means your control board may have suffered a fatal error. Unplug the unit for 30 seconds, when the power is re-applied if the error comes back you will need to replace the control board (ERC). Mike
F5 Board failure Replace control board (also called ERC or clock).
Mar 25, 2010 | KitchenAid KESC307 Electric Kitchen Range
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
    Hi
    F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
    1. Disconnect power to stove
    2. Gain access to the back of the clock (electronic range control or ERC).
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
    4. Make sure everything is clear and will not short out when power is turned back on.
    5. Turn power back on to stove.
    6. Watch for the F1 and listen for the beep.
    7. If you get the F1 and beep, replace the ERC.
    8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
    thank u
    rate me!!!
    Aug 14, 2009 | Maytag Ovens
    Err 2 message
    The ERR 2 code indicates there is a problem with the internal computer, specifically pertaining to the warming plate. I would advise you to call Kitchenaid Customer Service to see what options are available. They do not offer repair on the units, as it is not cost effective for the company or the consumer to have it repaired.
    Their toll-free phone number is 1-800-541-6390.
    Jul 01, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
    Display for radio stuck in '7 SAFE' mode
    This sounds like a Phillips Car Stereo:
    To get the code in:
    1. Turn the stereo off.
    2. Turn off the ignition
    3. Turn the ignition back on (dash warning lights on)
    4. Hold and keep down the AS button on the stereo.
    5. Turn the stereo on.
    6. Release the AS button after 4 dashes appear on the display
    7. Now enter code (if code = 7009. Press preset button 1 seven times, button
    2 once
    3 once
    4 nine times
    If you go past you can go round again by pressing the
    preset button repeatedly
    8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
    9. The stereo after beeping will scan to program channels
    You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
    Time delays work as follows:
    Attempt 1. 10 seconds
    Attemp 2. 30 seconds.
    Attempt 3. 10 minutes.
    Attempt 4. 20 minutes
    Attempt 5. 40 minutes
    Attempt 6. 80 minutes
    Attempt 7 160 minutes
    Attempt 8 320 minutes
    Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
    Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
    So, be prepared for a VERY long wait to be able to enter the code!
    Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
    May 09, 2009 | Car Audio & Video
    GOING NUTS WITH WASHER
    FL Flood condition"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
    With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. You will need to unplug this unit for 5 minutes. if you continue to hear beeps and the (FL) appears once more after the shut down, you will need to replace the water level switch.
    Press STOP/CANCEL to clear the display and unplug the unit for 5 minutes.
    Apr 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Cuisinart grind and brew beeps, but won't brew
    we unplugged it for 10 minutes or so, plugged it in again, beeping stopped and it works again.
    Nov 16, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
    KitchenAid JAVASTUDIO KCM534 14-Cup Coffee Maker Logo
    362 people viewed this question
    Top KitchenAid Coffee Makers & Espresso Machines Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Sal De
    Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
