Hard drive locked on other computers
I have come to unlock my hard drive at someone elses computer to move some files around.
  • Thomas F. Schneider May 11, 2010
    ??????????????? Locked hard drive?
    President:
  • 948 Answers
You have security software installed on your hard drive that prevents it being read if it is stolen. You must find out what security program you are using and follow directions from their documentation to unlock it.
Posted on Jan 01, 2009
Using nexxtech 2.5
its just maybe that the device is not compatible with linux. try that to windows xp and see what happen.
CHARCOIS
Aug 27, 2008 | NexxTech Computers & Internet
Wd my passport retrieve data
Step 1:
You might not have the appropriate software installed on your computer to show / read the files
IE: adobe flash , directx , win zip , codec , word ...... Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
Feb 08, 2013 | Western Digital 1TB My Passport Essential...
Iomega 1tb drive have files hidden
Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available. Hope this helps.
b>
Dec 10, 2012 | Iomega 1TB Prestige External USB 2.0 Hard...
I believe my hard drive is locked. When I try to plug in my hard drive to someone else's computer I cannot drag anything into it. Thanks for the help!
For some hard drives, you need to have the correct driver installed on the computer in order to use it. Especially if it is a USB device. If not try a different usb port. The port your using might not be working properly. If that doesn't work... turn off the computer and plug the hard drive in, then turn the computer on. The computer may need to recognize it on boot up.
May 12, 2011 | ClickFree (225-1001-100) 250 GB USB Hard...
I'v inserted my flash drive on other computer and try to save some files, after saving i inserted it to my computer and scanned it. wen i was removing the virus, dialog box told me that it cannot delete...
There is a free program called unlocker which will allow you to delete,move or whatever you want with a file. this program will even delete protected system files. you can find it here http://ccollomb.free.fr/unlocker/
Mar 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do I move a file from one computer to another
The mac computer should be able to read your Windows partition, but be warned that it will not work the other way around. There are many ways of moving the file, such as copying to a flash drive and plugging the flash drive into the Mac computer, or e-mailing the file to yourself.
Mar 03, 2009 | SanDisk Open Box 1GB Cruzer Mini...
External drive not showing up at all
i was working with (easy hard lock) and than i lock my external hard drive
now i cant get access to my external hard drive
(the program said dont lock external hard drive but i did i didnt know that )
can someone help me please
thanks
Jan 21, 2009 | Western Digital My Book Essential Edition...
Hi, I lost user manual, need to restore files back to computer.
Provided that you can find your external drive using My Computer feature, double click on that drive icon and search the drive for the files you wish to put on the computer drive (C drive). If you right click the file or folder on the Maxtor external drive and then choose copy, you can go to the folder on the C drive that you want to paste them into, select it and then right click the folder icon and choose paste to put them into the folder. To make the process quicker, you might choose to paste all files and/or files from the Maxtor drive onto the computer desktop and then move them around later.
Dec 27, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Unlocking my Maxtor on my computer
you will need
1. Windows 98 se bootdisk
www.bootdisk.com
2. AtaPWD
http://files.filefront.com/atapwdzip/;7100406;/fileinfo.html
Make a windows 98 se bootdisk
copy the atapwd files in there
start dos
Unlock the harddrive.
Nov 08, 2007 | Computers & Internet
Computers & Internet Logo
473 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
