Question about Onkyo CS-325 Shelf System
Onkyo 325 model- burning smell
Have had this unit for a week now, absoulutely fantastic sound. It does however have a burning smell coming from it still. I assumed it would be there for the first couple of plays to burn off any dust, but it is still happening. Have you come across this before?
Many thanks.
Jamie Churches.
  • Gary
    Gary May 11, 2010
    Could the smell be described as a "hot plastic" kind of smell, like of a new product that is running hot? Was this a brand new unit purchased or previously owned?
  • 883 Answers
SOURCE: no sound from my new (refurb) onkyo receiver
check speaker fuses.
Posted on Jun 10, 2007
PW47
SOURCE: Re: onkyo pre-amplifier (model P-3150V).
ONKYO PREAMP P3300 REMOTE SUBSTITUTE
Posted on May 16, 2009
mlapres
  • 757 Answers
SOURCE: This ONKYO TX SR505 unit
There are two things you can try. After checking the rear panel for any sign that an arc occurred; which can be identified on the chassis or terminals by an area that appears to have been hot or you have discolored input/output cables near the terminals, press and hold the power button on the receiver until you hear a second "click" from inside the chassis.
If the unit does not perform this action, check the outlet for damage or it is a GFCI type outlet check to see if it needs be reset. If none of those conditions are present, then leave the unit unplugged for 30 minutes.
Posted on Nov 01, 2010
ginko
  • 19396 Answers
SOURCE: Onkyo DV-SP406S - does not play whole files of
Hi.
That depends on the firmware. Unfortunately there is no Firmware Update for this model.(here page).
The only way to address the problem is using a file splitter. If you record the two consecutive files that you obtain from splitting the original movie into the same DVD, the player will play the files one after the other like if it was a single movie (no need to use the remote).
Here a free file splitter: Free Movie File Splitter.
Regards.
Ginko
Posted on Sep 04, 2011
  • 6771 Answers
SOURCE: Hi have a Onkyo TX-SR601 after using it for a while it shuts down.
The problem could be bad solder connections on the main, or the audio outputs are breaking down when they get hot.
Posted on Mar 11, 2012
Sparks from Onkyo TXNR 609
Hi try turning the unit on without any speakers connected ,if it still want power up just take it to a servis . ;)
Feb 03, 2014 | Onkyo TX-NR609
Burning oil smell after short drive beneath car under driver. No leaks or panel lights showing. Entermitten knock sound between radio panel and auto stick shift. Vehicle runs good. Noise started last week.
OIL BURNING SMELL PROBABLY COMING FROM THE EXHAUST AT TAIL PIPE WHERE CAR BURNING OIL.KNOCK NOISE AT RADIO AND TRANSMISSION SHIFT STICK COULD BE STICK SHIFT LEVER MOUNTING BOLTS COULD BE LOOSE OR SHIFT LEVER BROKEN.
Sep 21, 2010 | 1997 Toyota Avalon
I got a new Onkyo Cs-525 with Onkyo speakers a month back. My vendor said that it will take 300 hours of playback before my speakers completely burn and start giving the the best possible output. Now I...
Burn-in? On speakers? Never heard of it, especially for something not pretending to be sky-high esoteric and expensive, following the believing-is-seeing (or hearing) rule.
If I had to guess, I'd say you're hearing speaker buzz from stress or resonance from something in or near the speakers. Does it manifest itself at all levels, both speakers, all sources (analog and digital)?
Wild guess... are track lights present and ON when you hear the problem?
Aug 03, 2010 | Onkyo CS-325 Shelf System
Onkyo CR-325
According to the manual, the sleep timer can be set to shut the unit off after a specific time. The other timers can only be used to trigger the amp to play or recored at specific times, and only if the recieiver is left in standby, otherwise the timers are ignored. There should be no reason the sleep timer does not work if you are following the procedure outlined in the manual (http://safemanuals.com/user-guide-instructions-owner-manual/ONKYO/CR-325-_E)
Sounds like the transformer or something went in the other amp. Not related to the timer issue. Both amps having the smae timer issue suggests that it is a programming issue (follow the procedure in the manual step by step), if you still cant get it to work, get it covered under warranty while you can.\
Hope this Helps
Jer
Jan 15, 2010 | Audio Players & Recorders
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
HEAT PUMP/AIR CONDITIONER UNIT SMELLS ONLY WHEN AIR IS ON
Not sure what the smell...smells like.  My guess is dirt or dust near the heating elements.  These will cause a burning smell.  Sometimes insects even get into the act..building webs.
You will have to clean that area out...sometimes a large blower or vac can dislodge the dust.
Dec 04, 2008 | LG LS-K1830CL Cool Mini Split Air...
Not receiving power
unless you have repaired circuit board assemblies in the past including replacement of board traces, there is little possibility of home repair here because ".... think i did smell something burning before". Sometimes the manufacturer will include an on-board fuse. You can open the case and look for this, but it may be too late. Fuses may never emit a burning smell even after they "burn", unless it is a slow-type and not encapsulated and you have a keen sense of smell. Sometimes the power section may include large power resistors; large because of the wattage they must dissipate. Look for one of these burnt and replace, but he actual burned part may be hard to find unless you have very good bench-testing tools and instruments. Bottom line is ...highly unlikely, "can i fix it on my own".
Dec 21, 2007 | Onkyo TX-8210 Receiver
Onkyo CS-325 Shelf System Logo
172 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
