Question about Uniden TCX860 Cordless Expansion Handset
Deregistering a phone you can't find
I have more than the number of phones that my base will control. A couple of these have been lost or discharged, so I can't deregister them in order to register the valid "extras" that I have laying around. The base won't deregister them if it can't "find" them. thanks dottye
    Problem Solver:
  • 8 Answers
I had trouble deregistering one of the phones, as it has to be close to the original base (kept telling me out of range). I found out that pressing END and #, also deregisters.
Posted on Aug 25, 2007
Load eep def
Is this a car?
Could it be a phone?
Sounds like an AT&T phone issue.
Look at discussion of deregistering and registering a phone that had that error message.
https://jpwhiteblog.net/2011/03/09/how-to-register-an-orphaned-att-92370-handset-to-a-different-base-station/
Mar 05, 2018 | Cars & Trucks
How do i deregister an orphaned AT&T TL92273 handset?
  • Press and hold handset locator on base station until 'in use' light comes on.
  • Press # on the handset and the phone registers itself to the base station.
I repeated the above procedure with my two remaining handsets and now I have a 6 handset cordless system for my home.
It's important to note that if you have a working base station you should use the standard instructions for deregistering the handsets. Each handset gets allocated a handset number by the base station, if you deregister using the special code detailed in this post then the reserved handset number on the base station is consumed and cannot be reclaimed; thus reducing the number of handsets the base station can support by 1. The special code is only for use when you have a handset that is orphaned from a lost or non-working base station. www.apparelstore38.com
Jul 14, 2017 | AT&T Lands Phones
Our phones keep saying searching, but nothing happens. We tried deregistering the phones and registering again, but it doesn't work. We tried unplugging everything and plugging it in again, but still...
It's likely that the transmitter located in the base station has failed. Your handsets are looking for an answer from that station and not receiving any.
If not still under warranty, it may cost less to replace the whole system than repair the base station even though most of the electronics that makes the system 'cordless' is mostly dependent on a packaged RF module that costs only a few dollars wholesale.
Dec 01, 2010 | Uniden DECT15803 Trio Cordless Phone
My uniden phone says - out of range
I just finished fighting my phone for this same problem.Try unplugging the base for a minute and plug back in. I had a dead battery, changed it, it still said out of range. Next I deregistered it by holding the "off" and # buttons until the menu popped up saying "deregister". I had to select "deregister without the base" to get it to work. After all this, I unplugged the base, and that is what solved my problem.
May 25, 2010 | Uniden TRU9585 Cordless Phone
Phone says ''Welcome ... please wait'' when you try to use it
I tried to copy and paste the solution for this issue, but Fixya only allows so many charecters and I guess the answer is too long.
Go to http://www.uniden.com/index/manuals_results.cfm?cat=1
and select the owner's manual for your model phone. Follow the procedures for deregistering the handsets and then resetting the base. then re-register the handsets and you should be good to go. It is all pretty easy, just a little to wordy for this forum I guess.
Apr 04, 2009 | Uniden Cordless Phone
The hand set unit has a lot of static.
Try DeRegistering and ReRegistering the handset:
From the base system:
  • Press Menu
  • Scroll to System Settings - press select
  • Enter System PIN - press select (default pin is 0000)
  • Scroll to Mobile Deregustration - press ok
  • Scroll to the corresponding intercom # - press select
Then turn on Handset:
  • Please Register will be displayed - press ok or Register
  • Enter System PIN - press ok
At Base:
  • Press Menu
Back to the Handset:
  • When Select Intercom Number is displayed, select the number - press ok
Hope this helps!
Nov 11, 2008 | Siemens Gigaset 8825 Cordless Phone
I have a panasonic phone model number KX-TG6022B and wheather the phone is on the base or not, it says line in use. The line isn't in use though. I've tried unplugging both phones from the base and wait,...
sounds simple
3 things to look at
lets start with obvious i hope you have manual for phone still cause typen instructions for deregistering phone is long type
the reason phone could be showing its still in use is because phone needs to be deregistered and then reregistered back on the hand set base
the other thing is one of your neighbors has tapped your phone line giving you this busy signal
or say you still using dial up on your comp this will show a busy signal cause its using your phone line to get online
Jun 01, 2008 | Panasonic Lands Phones
Registering
place on base the will register your handset but make sure battery is charged now to deregister hold # end call button together for 8 seconds follow instructions for deregistering then once done place on handset to register
May 31, 2008 | Uniden Cordless Phone
Cordless handset doesn't work
same problem here. i've tried deregistering the phone from the base and trying again. still wont work.
Dec 30, 2007 | Panasonic KX-TG5632 Phone
Won't register
hi follow these steps and you will so great:( page 8) http://broadband.motorola.com/consumers/products/md7001/downloads/MD7001_Series_Users_Guide.pdf wont work try deregistering and then register again good luck
Apr 09, 2006 | Motorola Mobility MD7001 Cordless...
Uniden TCX860 Cordless Expansion Handset Logo
1,173 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
