Question about Frigidaire GLEQ2152ES Electric Dryer
The dryer will only run for ten min. it also wont get hot
It also wont get hot and has the message AD flashing
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the message displayed "AD" indicates that the dryer is in Auto Dry mode. it will sense the temperature of the clothes. It will adjust its running time to an estimated/computed drying time based on the algorithm of the logic controller. Simply put, if the clothes placed inside are warm, then the dryer will only run a short span of time. It is not an error code but a condition/status.
Good luck and Thank you for using FixYa.
Posted on Dec 29, 2008
    Master:
  • 479 Answers
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Kenmore dryer code ad
The "Ad" in the display indicates that the dryer is in the Auto Dry cycle.
The dryer will run in the Auto Dry cycle until the moisture sensor bars detect no more moisture in the garments being dried. The machine will then go into a cool down period and then end the cycle.
If the dryer is getting unusually hot, I recommend checking for a restriction in the air flow. Make sure that your lint screen is properly cleaned before starting every cycle. Check the flexible vent hose behind the dryer for a kink or a restriction. Check the exhaust ducting to the outside of the house for lint build-up or a restriction. This may help the dryer perform properly.
Sep 16, 2014 | Kenmore Dryers
Dryer will run but will not heat and the lights all flash
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# GLEQ2152ES, will run for a few minutes and then stop and display "AD" with the lights flashing. The "AD" means that your appliance was in an automatic dry mode. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire GLEQ2152ES Electric Dryer
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
When the dryer starts it makes a horrible squealing noise and then stops running within 5 mins..all lights flash on with error code Ad...no clue what I should be looking for to fix this
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 19, 2011 | Electrolux Frigidaire Affinity 5.8 cu. ft....
The dryer produces heat but shuts of about 15 min into the cycle you can turn it right back on ad it shuts off in about 15 min again
7) Runs for a few minutes then quits:
This is probably the motor going bad. The sensors wont cause this to happen. The start switch either, replacing all the sensors in the world wont make the motor be good again. But their is something you can do to try and make the motor last a while longer,their isn't any holes to oil the dryer motor so you must make some,using a 1/8th inch drill bit make a hole in either end of the motor where the bearings are (taking care not to hit the shaft), then add some hi temp oil such as zoom-oil, (don't use WD-40) and work the motor free as you can by hand. If this frees up the motor it may go a while longer. Also oil the rollers and check the slides to make sure they are not pinching and stalling the motor. If the motor can't reach top speed it will get hot,overload and stop.
found this while trying to solve my own problem....hope it helps as i have same problem
Jan 17, 2011 | Whirlpool WED5300S Electric Dryer
My Frigidaire model GLEQ2152ES0 will run but the air does not get hot.
Need to order the resistant heater, use the mothel of the unit to make the orther
Aug 11, 2009 | Frigidaire Electric Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
Runs for about 15 mins, no heat and flashes AD
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 18, 2009 | Electrolux Frigidaire Affinity AGQ8700FE...
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
Maytag performa dryer won't run right
bad motor,,should have change it when you had it open,,thats the overload you hearn inside the motor,,when hot it clicks off and when itcool it will run a while than click off...again...need help changing ..
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
105 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
