Question about SanDisk Sansa m240 MP3 Player
Recognise my sansa
Tired. But will try. Now on a new pc with Vista. cant transfer my music onto my mp3. Error msg says cant recognise.
Go to Control Panel and Click on add hardware.
Posted on Nov 20, 2007
The sandisk sansa m240 1 GB player is also recognized by Windows XP "My Computer" or "Explorer". To make the windows XP operationg system to recognize the player it requires a little change in the player setting itself. 1. Go to the player menu 2. Go to settings 3. Go to USB 4. Select MSC (Generally by default it is set to "Auto detect") AND YOU ARE THERE!!!!! The player is shown as a new hard drive in My computer / Explorer -- Tridib Khanra
Posted on Jul 09, 2007
Kindly see, if this helps. My sister's Sansa M240 couldn't be recognized in Windows XP "My Computer". But, I tried to open Devices from Real Player. It worked.
Posted on Jul 03, 2007
On the Sansa, settings menu make sure USB is set to autodetect. Uh, I also tried another USB port, so I'm not positive which fixed it! So much for the scientific method.
  • 33 Answers
To old for vista to recognize
Posted on Apr 30, 2007
SOURCE:
The computer wont recognise my mp3
try messing with the usb settings on the mp3 player in settings/ system settings/ USB mode/ for a newer PC try MSC for an Older PC or mac try Mtp and if that dosen't work try auto detect just mess around with it fir a while
Apr 09, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa e200
There is one option, not really a fix, just a workaround. Try the player on a different computer computer and see if it is recognnised there. If it is, then use something like a pen drive to transfer music from the PC that doesnt recognise the device to another that does. Now you can transfer music using the WMPlayer sync service.
If your device is not being recognised on many computers, it looks like it is time to chuck it away. You can also try this first though..
1. Remove the player from the PC and switch it off.
2. Restart the computer.
3. Hold the +Volume button and connect to computer.
4. Keep the button pressed for at least 60 secs, and you should see the "Found New Hardware" balloon pop up, indicating that the device has been detected.
If even that fails, then I'm afraid your Sansa player has run its course, and you may need to purchase a new player...:(
Jun 27, 2008 | SanDisk Sansa e200 MP3 Player
I can't transfer music
hey you cant use windows media player. you have to use bestbuy digital music store.
Feb 08, 2008 | SanDisk Sansa e250 MP3 Player
I don't know how to load music from the internet to my new mp3
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel1.gif Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data1.gif folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 28, 2008 | SanDisk Sansa e200 MP3 Player
Cant load songs
Windows XP SP1
Intel Pentium class PC or higher
CD-ROM drive
TRANSFER MUSIC
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
PC not recognising hardware
I have had the same probmlem but I've begun to realize that windows vista isn't compatible for the MP3 player when I tried using it with Windows XP -- and it worked fine.
Jan 07, 2008 | SanDisk Sansa m240 MP3 Player
Transfering Music
I have the same problem when I use Windows Media with Vista. I have tried everything to rectify the problem....Now I simply use Real Player or Yahoo Jukebox to transfer my music.
Jan 04, 2008 | SanDisk Sansa e200 MP3 Player
Sandisk sansa c250
It sounds like you have a music subscription with some music company...download a new song and transfer it to your device...that should solve the problems..if that doenst do it..format your device and tried to transfer song again..
Jan 03, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Problem downloading music
You must convert to mp3 or acquire a DRM license
Nov 20, 2007 | SanDisk Sansa e250 MP3 Player
Im trying to copy music from my sandisk sansa m230 onto my windows
You can open the device under COMPUTER>Device Name (m230)
Open the MUSIC folder and just copy the contents to your computer by dragging and dropping them onto your desktop, or other location.
Best of Luck.
Nov 02, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
126 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
