Question about HP FAX 1250 Fax Machine (Black)
Not printing replaced cartridges on hp1250 fax, and now it won't print. Someone faxes me, and it comes out blank
    Problem Solver:
  • 7 Answers
First configure and enable the setting on the control panel area,then be sure that the plastic cover on the tip side is removed.
Posted on Dec 29, 2008
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
Hp office jet K80 recieves fax, sounds like it is printing but pages are blank
It sounds like an empty cartridge. check your cartridges, it may be time to replace them. You have to give more information like did you try a print test and if so did it print ok? have you tried to have someone send you a test fax from different numbers?
Jul 17, 2010 | HP OfficeJet K80 All-In-One InkJet Printer
When i recive fax or when i print it just it prints empty page
If the fax is acting like it is printing (print head moving back and fourth) then it sounds like the ink cartridge is clogged. Remove the cartridge and clean with cotton swab and rubbing alcohol. If this helps a little or not at all replace the ink cartridge. If it still prints blank, the print head could be the problem (this is where the ink cartridge goes). At this point it would be cheaper to replace the fax.
May 14, 2010 | HP J3680 Officejet All In One Printer
Fax will not print test page comes out blank
Try another cartrige or clean the contact points of your print head.
Jul 29, 2009 | Samsung SF-350 Plain Paper Inkjet Fax
HP Office Jet 630 will not print
please check whether the data cable rx232 which is used to connect the printer to pc is fine. try someone else's cable(e.g friend) and check whether it is able to print .re install the software that is provided along with the printer in the form og cd or dvd. hope your problem will be tackled then
May 25, 2009 | Office Equipment & Supplies
Fax printing out blank paper
New print head, might be cheaper to replace machine
May 21, 2009 | Brother Fax-1360 Plain Paper Inkjet Fax
SENDING FAX COMING BACK BLANK PAGES .NOT PRINTING ATALL.
If you attempt to print any kind of report from your unit and the pages are still blank there are two posibilities.
#1 The toner cartridge tape was never pulled out correctly/ the toner cartridge might be defective.
#2 A more serious cause fo the same symtom might be a defective hi voltage section in the unit. On a newer product this is not very likely
May 13, 2009 | Canon FAX-L1000 Plain Paper Laser
HP 640 Fax series not printing
If it is a color printer, try printing just grayscale or black& white.  It is is already set to print just b/w, try printing in color.  Basically you may be out of ink.  Run the printer utility to clean the heads and see if anything changes.  A new set of cartridges should fix the problem, I believe.
Hope this helps...
~enov8
Feb 16, 2009 | HP 640 Inkjet Fax Machine
DOES NOT PRINT INCOMING FAX- PAPER COMES OUT BLANK
Have you tried a new toner cartridge?
Did you pull the plastic tape on the cartridge?
Mar 21, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
The fax will not print anything
2 possibilities
1- you did not remove the plastic film on the cartridge
2- the printhead has dried up
Dec 04, 2007 | Sharp UX-B20 Plain Paper Inkjet Fax
HP FAX 1250 Fax Machine (Black) Logo
62 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
