Hi we have a hotpoint washing machine. the machine is some thing error . eg...check out let pipes
  • Washing Mach... Master
  • 3,463 Answers
That means it is not draining the water for one reson or another.
Check the drain hose is clear of any blockage or obstruction.
If it has a removable filter at the front, then take it out, and clean it.
If the outlet pipe goes into your sink waste, disconnect the connection onto the waste and check for blockage there.
Try pumping the water into a bucket to check for flow.
Plz rate my soluion.
Thanks.
Posted on Dec 29, 2008
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint washing machine (wm 62)and it jumps whils starting to spin. this is a recent problem and i find i have to move it back into position following every wash.
Hi.
You have a balancing problem.
The first thing to do is checking floor level and putting the machine at balance as explained in the user manual (see
Installation and User Instructions for the Aquarius Range). If that does not work there are internal faults that may result in heavy shaking during spin part of the cycle. Such problems are mostly mechanical (eg. struts, bearings, rollers, springs), the machine must be disassembled to locate the problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 09, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Getting an error messsage on my hotpoint ultima wm72 code is e30
It means motor problem, see below
It could be as simple as the motor requiring new brushes which can be bought quite cheaply on ebay or as complicated as the pcb motor controller being faulty. The brushes are however easily checked
http://www.youtube.com/watch?v=0GmtRBiXLFc
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.Read on....
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Hotpoint Error Messages and Error Codes
The following are an explanation of specific error codes that may appear if there is a problem with your Hotpoint washing machine, tumble dryer, dishwasher, fridge or freezer. In most cases it is recommended to book a service engineer to rectify this fault but there are certain things that you can do to minimise any inconvenience or even avoid an unnecessary engineer visit.
Don't forget, should our advice fail to solve your issue then you can book a Hotpoint appliance repair . Alternatively phone us on 08448 224 224 to book your washing machine repair.
If an explanation of an error code on your Hotpoint appliance is not shown please contact us for an explanation
Hotpoint Washing Machines and Washer Dryers
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred. Book a washing machine repair
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a washing machine repair
  • F17 - Door not closed properly. Close door firmly at the 3 o'clock position.
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing. Book a washing machine repair.
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book a service engineer.
  • F40 - Water below protection level during a heat step. Book a washing machine repair.
  • F41 - Water level detect sequence incorrect. Book a washing machine repair.
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language). Book a washing machine repair to re-programme your product.
Feb 26, 2011 | Hotpoint Washing Machines
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ulitma washing machine that is
Error code E15 means pump time out, that it is to say the water is not pumping out enough in the time alloted by the control module.
There must be some kind of blockage or restriction in the pump or the outlet hose, so you need to check these.
Please rate my solution.
Thanks.
Jan 19, 2010 | Washing Machines
Hotpoint aquarius wd440 confusion over washing machine pipes
Hi is there another valve? If so then you can connect them by a Y piece. Problem solved.....
Feb 26, 2009 | Washing Machines
Error code F-08
Hi
Did you fix this? I have the same issue.
Sep 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wf860 - H2O Error Code - Machine is asking for water but draining it straight out
Check that your outlet pipe rises above the stated height on the back of the machine (about 3/4 of the way up). If it is too low, it will siphon the water out of the drum. If you're not sure what height it should be at, raise the top of the pipe (ie where it bends back into the outflow pipe) above the top of the machine (if you have room) or as high as you can. It must be above the height of the drum.
Good Luck
Jan 06, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error E15 - MAchine not draining
drain is same wehatever the program. filter is likely blocked. access is not that easy. take off panel at bottom rear. filter is in pipe from bottom of tub to pump. undo this pipe, take out filter. you may have water everywhere so be carefull
Nov 10, 2006 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
Top Washing Machines Experts
