Question about Roper RAS8445KQ Top Load Washer
Washer wont spin
Roper model ras7133rq0 washing machene
All cycles work fine but tub will not spin
The coupler between the motor and transmission apears to be ok it turns when in spin cycle the clutch looks like it turns but tub will not spin could it be the clutch is messed up how can i be sure
Thank for your help
William
  • tunicaprinte Jan 09, 2009
    The clutch was bad not the transmission I replaced the clutch washer works fine
  • 21 Answers
If the coupler and clutch are ok and you can hear the motor functioning, then it appears that your transmission is bad.most of the time you will see that in the days/weeks leading up to this that your cloths were more wet than usual when you took them out of the machine. Check your owners manual for warranty information. Some machines had a 5 year warranty on the transmission or gear case as whirlpool likes to call it.
Posted on Dec 29, 2008
The machine will not spinn, the washing is very wet when finnished washing
clothes are wet after spinning this is due to faulty Motor coupler. test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:If it's spinning when you lift the lid, the coupler is fine.If not then the coupler is broken.It has to be replaced;.This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. ----------------------- If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn motor pulley or tub bearing. Replace the applicable component. Thanks.
Sep 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
I have an old model 110.82074110 that is slow int he spin cycle. I believe it is slipping in the basket drive. Is there a way to adjust? Thanks in Advance Larry
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Jan 02, 2010 | Washing Machines
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
RAS6233KQ2 TOP LOAD WASHER WILL NO SPIN CLOTHES
Nov 03, 2008 | Roper RAS6233KQ Top Load Washer
Whirlpool Washer LSR7233BQ2 Buzzes/Humms during spin cycle...no movement
No belt on your machine. Sounds like motor coupler that joins motor and transmission is broken. Very inexpensive part but a few steps involved in getting machine disassembled Look up YouTube video on replacing motor coupler on Whirlpool washer.
Sep 26, 2017 | Whirlpool LSR7333 Top Load Washer
Spin cycle
IF its not your drive coupler (between motor and tranny) You could have something in your pump or a bad motor.
Oct 07, 2008 | Roper RAS8445KQ Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Washer won't spin
Check the belt to make it has not snapped or is tangled. There may also be some kind of visible obstruction in the way.
Also check: the motor coupler may be broken. Many washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
If it seems that washer tub doesn't spin freely it may be seized and expensive to fix this would need to be checked by a repair technician.
It is possible also that the transmission is worn if the tub starts to spin and then stops. This is also a repair technician job and could be expensive for a old machine that parts are hard to come by.
REMEMBER to unplug the washer before working on it to avoid injury.
Feb 19, 2008 | Roper RAX7244KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
104 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
