Question about Philips 32PT6441/37 32" TV
Picture is too large for the screen, horizontally.
When you turn on the power picture comes right on. But, if there are words spread across the screen the ends of them will be missing on both sides. It looks as if the picture is too large for the screen. Even the faces appear to be wider. Aside from that the picture, the sound, etc. seems to be working fine. We tried to go through the remote functions to determine if something may have been out of adjustment. As far as we can tell everything is fine. We think that it has something to do with the horizontal. Is there a way to manually adjust this on this particular model?
    President:
  • 3,130 Answers
No my friend, there is a problem with the width circuit, and this would be in the pincussion correction circuit of the TV set. There is alot of high voltage in this circuit, and if you have no TV repair experience, play it safe and call in a tech to service this for you. there is not any adjust ment that will fix this. Good Luck
Posted on Apr 29, 2007
Black "blobs" on PC monitor
hey there I think the problem is your magnet. Make sure to never keep magnets near your laptop. A magnet can erase the data off your disk and cause issues with your monitor. Anything that uses electro-magnetism to function will be affected by magnets.
Cheers mate!
Oct 16, 2017 | Dell Computers & Internet
It is a crt 17"
if its a cathode ray display its got vertical scan problems then its the line timebase more than likely a resistor gone high value or a leaky capacitor take the board out and have a good look for burnt out resistors and printed circuit damage change any electrolytic capacitors
Feb 22, 2018 | Zenith Computers & Internet
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about...
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
Aug 21, 2010 | Samsung LN46A530 46 in. LCD HDTV
I have a Flat screen Sony Bravia KDL-46S4100. Lines go across the screen horizontally about 6 inches apart. There is distortion especially on the right side mostly on lower right. What needs to be done to...
Are the lines all the way across the screen? or just a few? Solid black - or trannslucent?
Like this??
Horizontal drive has either data, voltage, or control problem from the pixel registry circuit......get it serviced before the problem spreads causing further damage.
However, in all likelyhood, the panel itself is bad. The Bravia line has had a bad rap about the faulty displays, and at $1800 replacement (plus labor) - it may be time to call SONY direct to complain!
Thanks!!
nc
Apr 02, 2010 | Televison & Video
Picture on RCA TV shrinks to a horizontal line
Sounds to me you have a cold solder joint ( loose solder connection ) on the printer circuit board around or on the vertical chip or on one of the vertical capacitors. You may also have a bad vertical chip or a bad vertical capacitor, but I doubt it since it did come and go. I'de get a soldering iron and some solder and touch up the connections. I will remind you that you need to always excersise saftey by making sure, before removing the back, unplug the TV from the wall, and use care not to come in contact with the large red wire going to the back of the picture tube as the picture tube can be turned off and still store lots of voltage ( up to 35,000 volts). Always stay safe and when soldering, use care not to run solder across places that will make a short.
Good Luck and I hope this helps
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
307-266-4675
Dec 19, 2008 | Televison & Video
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Toshiba 32A43 Horizontal Bars, pop, no picture.
First of all, there is no such thing as a "high power flyback converter". There is a flyback transformer, but if it was bad you would have absolutely no picture at all. The fact that you dont even know what the basic components are suggests that you should not be "diving in" to someone else's TV. Do everyone a favor and allow an experienced tech to service the set.
Jul 24, 2007 | Toshiba 32A43 32" TV
Philips 32PT6441/37 32" TV Logo
125 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
