Question about HP LaserJet 3030 All-In-One Printer
My printer makesa churning noise. There is a black line on the right of the paper.
  • 43 Answers
Do a half self test. To do this print anything and open the cartridge door when paper feeds into the printer but before it reaches the fuser. This will tell you if problem is with toner or fuser. In order to check the fuser remove toner, in back of printer you'll see a cover held in by 2 screws. remove screws and gently pry cover enough that you can shine flashlight and see the fuser film. If torn replace fuser.
Posted on Jan 14, 2009
Printer will not print
reinstall usb and printer drivers and check settings
of printer
see that head of cartirage is ok
nozzels shall be jammed
Jun 03, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My van is making a sweaking noise in the area of the belts and pulleys. i have replaced the tensioner assembly, belt, idler pulley, alternator and battery. whats the problem?
take a long pole as from a push broom and use the pole as a stethascope. place the pole to the power steering pump at a safe aera and place your ear to the other end of this will hear the churning of the bearing as the engine is running. do this to every part that runs off the belt. you will notice a big difference when you listen to all bearings. if all sound good as a normal churning noise you have a glaze of dried oil on your pulleys making the belt to sqeak
Feb 20, 2010 | 1997 Dodge Grand Caravan
Right turn wobbling noise
check the drive axles and hub bearings checked
Feb 12, 2010 | 1997 Subaru Outback
HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Jan 01, 2009 | HP Color LaserJet 2600n Printer
Printer HP laserjet 3030
It sounds like a faulty toner cartridge.Try changing the cartridges and see if this solves the problem
Dec 29, 2008 | HP LaserJet 3030 All-In-One Printer
How to interrupt a printing job and cancel it
Hi, I hope I can help.
Your printer has some of the pages stored in memory, and your computer also has some of the pages stored in the memory (spooler) on your computer.
If you turn off the printer, the computer thinks the printer went off-line and it waits for it to come back on, and then just keep churning off pages. OR.... Something will get messed up and 100's of garbage pages will start churning out.
The deal is to clean out the memory on the printer, AND clean out the spooler on the computer.
Simplest way (hopefully) is to turn off both units. That may solve it. However, sometimes the spooler on the computer will keep trying to print. Down in the lower right hand corner of your screen should be a picture of a printer. Double click that and you'll see the print job. You should be able to select the print job, hit delete, and clear it from the spooler.
Hope this works.
Feb 28, 2008 | HP LaserJet 1020 Printer
HP LaserJet 3030 All-In-One Printer Logo
83 people viewed this question
Ben Johnson
