Question about Sony MDX-CA580 MiniDisc Player
Car audio aux lead
I have a sony minidisc car player (model mdx-ca580) And I was wondering how to connect up a ipod to the aux. I have no problem connecting the lead (to the bus audio input) but i dont know how to change the machine to play whats playing through the auxilary. Do i have to change a setting to do this? any help would be greatly appeciated. Thanks
    Problem Solver:
  • 6 Answers
There should be a 'source' or 'mode' button that should switch between CD and AM/FM modes. This button should also swith over to the AUX input.
Posted on Feb 04, 2009
Fitting instructions
User Manual: MDX-CA580
Service Manual: MDX-CA580
Hope helps.
Apr 02, 2011 | Sony MDX-CA580 MiniDisc Player
I lost may mdx-ca680 conecctor. Does anyone have the drawing of the back pannel of the unit so I can take out the cables fron inside of the main board, but I need to know the cable´s...
Click Sony Support link to download installation manual copy that has all necessary info about connection jack/ connection setup at rear of MDX-CA680
Hope this will help you.
Thanks.
Nov 06, 2010 | Sony MDX-CA680X MiniDisc Player
Need wire diagram for Sony MDX-C670 Car Radio Mini Disc Player
have a sony mdx c670 car minidisc player, any advice on the wiring connections/
Sep 05, 2009 | Sony Car Audio & Video
Which cd changer is compatable with the mdx-ca580?
all are compatabel CD changers have only three (3) wires to hook up they work with any radio weather it is factory or aftermarket
Apr 28, 2009 | Sony MDX-CA580 MiniDisc Player
I have lost power to my sony cd player in my car
Take the cd player out and run the 12+V to + on 12+V battery.
Run the Ground/Black wire to negative on battery. See if the cd player will turn on. If it does, check your ground in the dash. This is just a good trouble-shooting method to make sure the cd player system board is not fried.
Feb 08, 2009 | Sony MDX-CA580 MiniDisc Player
Loss of sound after i start the angine
red - switched power (hot when key is on)
yellow - constant power (hot at all times - depending on the vehicle, i've used a direct battery connection, but isn't recommended)
black - ground
blue - power antenna or amplifier 'REM' wire
the other's, i'm working off of old memory....
purple - rear right
green - rear left
white - front right
gray - front left
wires with black stripes are ground, and without are hot
- if you're working on an older car, it sounds like your red and yellow are connected to the same power source. if this is the case, the time will always be resetting.
- if it's a newer vehicle, AND the time is not resetting, the red wire is connected to the wrong source. if the time and stations stay programmed after it shuts off, the yellow wire is correct.
Feb 03, 2009 | Sony MDX-CA580 MiniDisc Player
NO sound from my sony mdx-c8200
I had the same problem before with the same unit, and I found that the problem was only the recording format, you have to record your MDs in SP mode, this is because, the mdx-c8200 is a non MDLP MD compatible unit. So, if you want to listen your MDs on your mdx-c8200 just don t record em in LP mode, just SP mode.
Mar 14, 2008 | Sony MDX-CA580 MiniDisc Player
Sony MiniDisc car stereo
It sounds like you have a newer portable minidisc player, and an older deck. There were several upgrades over the years for ATRAC files, and some of the newer recording formats are not compatible with older players.
Nov 10, 2007 | Pioneer MEH-P5000 MiniDisc Player
Car compatibility
Bluesman,They Make adapter Kits,That can Plug in to your Existing Plugs of your Vehicle,Check your local Car Audio Dealer
Jun 20, 2007 | Sony MDX-CA790X MiniDisc Player
Sony MDX-CA580 MiniDisc Player Logo
346 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
